Old 07-29-2023, 07:24 AM
60s Throwback
1967 Magnavox U-919
Good morning. I have a 1967 Magnavox console with the U-919 chassis. What are some things I should look at that might cause low B+ voltage?
Old 07-29-2023, 08:30 AM
If its a voltage doubler PS there is one can thats insulated
from ground & usually cardboard covered. Common to
open.
Other than that quite a list of things.
Old 07-30-2023, 04:00 PM
Have you changed the lytics, how does the rectifier tube (if it isn't SS) test, any paper caps left in it?
Old 07-31-2023, 06:55 AM
60s Throwback
The set is all tube, and is still all original, except for most of the tubes.
