Cattle Prod Question
Memory fails me, but what was the name of the tool we used to call the 'cattle prod'? It was standard equipment for 'cleaning' every rebuilt CRT prior to installation. It was a hand-held, AC-operated high voltage probe that put out probably 40 KV or so of AC. You'd apply the "business end" of the Prod to the CRT base pins, and any loose particles inside would incandesce and fly around until they all 'stuck' somewhere and all the sparking ceased.
Yuppers. That's it. Thanks
I've used many of the coils in the picture in the URL. I own two of them.
I've never ever heard them called Oudin coils. They are always called Tesla coils. The pictured one is barely over the edge of being dangerous. |
I have one of those! Have one as a "souvenir". We called them Tesla coils too. Was used to check the seal between the glass manifold and tubulation on the image converter tubes at Varo where I worked in the '70s. After mounting a row (12) of unprocessed tubes, we would then pull a vacuum and check for leaks with the Tesla coil, bake out overnight and process the next day.
That device could also be called a type of induction coil.
They were popular decades ago as quack medical devices, usually with a set of gas discharge attachments. Now they are sold as "personal fun" devices, aka "Violet Wands". Last edited by Notimetolooz; 02-14-2021 at 10:40 AM. |
On some early Zenith CC2 17 & 19" sets focus would vary. Factory told us to
lay set on its face, pull CRT socket & ground the focus pin. Fire up set & listen for the snaps. Had a hand full of them & worked every time. They were all new sets under warranty. 73 Zeno ![]() LFOD ! |
The second one was at a CRT rebuilder, used to check duds if still under vacuum. I thought it was a form of VanDegrafe generator.
I'm probably going to start using it on my ceiling soon...we got some type of small varmints up there waking me up at weird hours of the night and they are ignoring the mouse traps...I figure if they chew in one spot long enough for me to pin point them (which they have before) and I can zap them through the drywall, then if they survive (they probably will, but I don't really want them to) they won't be back anytime soon.
If you want a close encounter just leave some peanut butter and cheese snacks on your bed. No need to burn holes through the ceiling.
Doesn't a true Tesla coil need the capacitance of a top load (big smooth sphere) for resonating the secondary? Or maybe 'tesla coil' is sometimes used in a colloquial sense.
https://en.wikipedia.org/wiki/Induction_coil |
Yeah, our cattle prod device was more like an an automotive ignition coil on steroids, with a built-in mechanical interrupter.
Mine is just a spark-coil thingie.
