Old 12-11-2017, 08:39 PM
mbates14 mbates14 is offline
Motorola VT-71 Composite/s-video in?
In a ditch effort to get my VT-71 back into full operation again, instead of using the tuner and attempting an IF alignment which uses gear I do not own, has anyone attempted to modify the set to allow a composite/audio input?
Audio is fairly easy and straight forward. But the video side, I am not sure. I was thinking about using A/V extenders. Put one at the DirecTV box, and the toher one at the TV. it has S-Video which is nice because I could get rid of the chroma signal, stick strictly with luma.
Problem is, Not sure where to inject that signal, its not as straight forward. Detector diode? would it be strong enough? or would I need serious modifications?
