Old 05-01-2016, 06:37 PM
dtvmcdonald's Avatar
tt-5 5BP4
I got the TT-5 I won at the ETF auction home and inspected it.
The CRT plug, if it is a socket, is falling apart. The wires are
100% OK however. It can be fixed.
BUT .. I can't figure out how the socket comes off! There is no
groove between the socket and what would be the plug if it were intact.
It is not the normal Bakelite plug! Its a very thing shell which appears
to be in two sections. Its hollow inside the the wires just flop
around. How does this thing work? It looks like I could grab
the shell and push of the inner keyed piece ... but I'm very afraid to try this.
What should I do?
Otherwise, the set look in good shape.
Old 05-01-2016, 09:06 PM
WISCOJIM WISCOJIM is offline
Photos might help so we can see what is odd about it.
Old 05-01-2016, 10:54 PM
Ill do that tomorrow. Tonight I finished
the project I was working on before the convention: a
set of switchable filters for Sw SDR radio. They make
a lots of aliases go away.
Old 05-03-2016, 08:46 AM
I figured it out with help from photos of tubes on the 'bay. Its a very bad socket
design, as you can't grab the actual plastic base to hold it as there is a lip
on the socket covering it up. I had to slowly pry my socket off with two screwdrivers.
Old 05-09-2016, 10:47 AM
The HV wires to the socket are dangerously old ... they are beginning to crack.
I have ordered new wire.
But how do I remove the contacts from the socket? My guess is that I
unsolder the old wire and pull it out, if it comes out. Then there are likely
little "spurs" on the contact that I need to push out to get it to came out.
Has anybody redone the wires on the CERT socket on one of these?
On the other hand, they are all clearly good enough and at close enough voltage,
that I could just wrap the whole bundle with cut-open vinyl tubing and cable-tie
it together, to protect me.
Old 05-09-2016, 11:19 AM
vts1134's Avatar
vts1134 vts1134 is offline
Looking For Time
I have ordered new wire...
Where did you find the wire? I tried looking for replacement wire a while back and could not find anything.
John
Old 05-09-2016, 06:31 PM
Up to 10 kV Mouser has it. Odd place.
Go to manufacturer Pomona. Then search for wire. They have it
in 5 and 10 kV red and black, 50 foot lengths.
Above 10 kV I can find the manufacturers but no distributors.
and, of course, there's ebay
Old 05-09-2016, 07:03 PM
Above 10KV there is always the old rob the HV wire from a BPC CRT set sitting by a curb or in a field method...
Automotive spark plug wire (the non-resistive type) is another option, and should be available at the local auto parts store of your choice.
Old 05-14-2016, 09:16 AM
vts1134's Avatar
Looking For Time
Sorry, should have been more specific, I was looking for an exact replacement for the multicolored rubber coated wire. I know I can get a functional replacement.
John
Old 05-14-2016, 09:04 AM
Argggggggghhhhhhhh
Abysmal soldering job throughout this set ... right from the factory.
Big blobs of 50-50 or worse solder!
I can't even use a solder sucker without first adding 60-40 solder.
Old 05-14-2016, 04:46 PM
Well, there is black, white and red on ebay. They are quite close looking.
I found all the other colors, at their manufacturers. But no distributors.
Old 05-14-2016, 11:04 PM
TT5 restore thread
My tt-5 restore proceeded well until this evening.
I recapped the HV section and all electrolytics plus a few
critical paper caps.
I then turned it on using a variac and dim bulb. Nothing sparky or
smelly happened. The HV section works ok as tested with my new HV probe.
The B+looks OK at slightly reduced line voltage.
The horizontal works fine.
The vertical is dead, apparently due to an open oscillator transformer
primary (plate) winding. This needs to be verified and if so checking
for bad wire connections.
Its supposed to be an RCA 32898. Can these by found? If not,
the circuit looks rather common, I've seen similar circuits
with different transformers. Is it possible to use a different replacement,
or find the specs to have this one rewound? would a generic 4:1 one with
appropriate resistances work (properly)?
Doug McDonald
Old 05-15-2016, 08:50 AM
An attempt to fix the transformer failed. Indeed there was a break at the small-wire
lead junction. However, the fine wire broke off at the paper.. Further investigation
showed that there were multiple patches of
corrosion in the few of layers of wire. Something
corrosive was there from the day of construction.
Old 05-15-2016, 11:35 AM
Sulfides from the paper? May be just an old wives tale, but several radio collectors that I know claim this is a real problem on pre war radios.
Coin collectors also seem to avoid paper envelopes for the same stated reason.
Old 05-15-2016, 05:18 PM
One of the worst things for coin collectors was the high sulphur content of the materials used in the blue Whitman coin albums of the late 60's-early 70's era. They could turn your choice BU set of 1941-1958 wheat pennies into severely spotted coins in less than a year.
