Old 08-10-2013, 06:46 PM
Console User Console User is offline
Antenna Flat Styled Wire
Does anyone know where you can still find some of that old 1970's-1980's flat brown two wire antenna wire that you use to hook up the antenna to the TV? I know it's not nearly as good as the newer coax cable I guess but would like to have some to make my Antenna and older tv setup more nostalgic like it was when I was growing up watching TV.
Old 08-10-2013, 07:31 PM
TinCanAlley's Avatar
There's someone on ebay selling four 6' pieces w/spade ends for 2.50 w/3.50 shipping. They seem okay for indoor use.
Old 08-10-2013, 09:38 PM
marty59's Avatar
marty59 marty59 is offline
Do a search and you'll come across some too. Most of the later twin lead wire was foam or heavy insulated. I prefer the cheap brown colored stuff when I can find it for making dipoles with and lead in wire repair on older sets.
Old 08-10-2013, 11:44 PM
WISCOJIM WISCOJIM is offline
http://www.frys.com/search?search_ty...bmit.y=0&cat=0
Old 08-11-2013, 07:50 AM
Called 300 ohm twin-lead. As said most is heavy foam lead.
A little digging & should be able to find a spool, even
the more retro thin stuff. It does have the advantage of
less loss especially at UHF, also cheaper than coax.
We used it in problem UHF installs when the customer was
too cheap to by an amp.
Old 08-11-2013, 10:35 AM
I was always under the impression that the plain flat twin was lossy at UHF frequencies, especially then wet.
Milwaukee was a UHF town from 1953, so there was a lot of outdoor antenna installations. A VHF conical and a UHF corner reflector. Two lines running down to the set. A flat 300 ohm from the VHF antenna and a tubular 300 ohm from the UHF antenna.
Old 08-11-2013, 11:13 AM
I am looking for the retro thin stuff. We used to have it up but threw it away when they went to coax cable. Don't know where to find that retro thin stuff. I can find the newer but haven't seen the retro flat brown stuff.
