Old 12-18-2011, 06:31 PM
stusnyder's Avatar
Hallicrafters model 600
Anybody on here own one of these? I have a chance to get one. Just wondering how common they are.
Old 12-19-2011, 12:48 PM
Originally Posted by stusnyder View Post
Anybody on here own one of these? I have a chance to get one. Just wondering how ommon they are.
I don't think too many of them survived. The last one I worked on was 40+ years ago. Most of them had a continuous tuner. They used that same chassis in models all the way up to 19" round. They even made them for Sears and others.
Old 12-19-2011, 01:29 PM
One learns something new every day.
I didn't know until now that Hallicrafters TVs had mostly continuous tuners (including FM between channels 6 and 7). I've seen photos of some Hallicrafters TVs from the late 1940s (table models with a very small picture -- couldn't have been more than 5 inches diagonal) with the push-button channel selector, which included channel 1, and a separate small fine-tuning control located next to the button for channel 13. Never saw a Hallicrafters television, however, with knob tuning -- continuous or otherwise. The set you worked on in the early '70s or late '60s must have been one of the knob-tuned models.
I did not realize, either, that Hallicrafters made the chassis for TVs sold under the Sears brand name, let alone other house brands. Always thought Hallicrafters televisions were made decades before anyone ever heard of rebadging home entertainment gear.
Old 12-19-2011, 09:57 PM
I don't remember those sets getting FM between the channels of 6&7 like the Dumonts. The tuner was a 3 tube job. The later Halli's had a turret tuner with printed circuit strips. Two tubes. They claimed, they made it themselves. The small seven inch e'stats were built for Wards and Delco.
Old 12-20-2011, 12:32 PM
That's strange. I would think any TV tuner built for continuous tuning would have to tune from 88 to 108 MHz, and then some (as did the DuMont Inputuner continuous tuner), since the FM broadcast band (and also the old, now obsolete 152-174 MHz police band, not to mention the 108-136 MHz aircraft band and whatever was between 136 and 152 MHz) are right in between channels 6 and 7. How did Hallicrafters design their continuous tuners to skip over the FM broadcast band when tuning from channel 6 to 7? scratch2: The only thing I can come up with is that the tuners had a high/low band switch, on the set or a switch on the back of the tuner, activated by the tuning knob on the TV itself, that switched the tuner directly to channel 7 from 6, thereby completely skipping the frequencies in between. That or else the TV had two separate tuners with separate tuning knobs on the front of the set, one for channels 2-6, the other for 7 to 13.
Old 12-20-2011, 01:25 PM
The tuner had 2 sets of antenna, oscillator and mixer coils. A 6 pole double throw switch, activated by the tuning knob switched from the low band to high band coil sets.
Old 12-20-2011, 02:52 PM
That's strange. I would think any TV tuner built for continuous tuning would have to tune from 88 to 108 MHz, ...and whatever was between 136 and 152 MHz)
That includes the 2 meter ham radio band, 144 to 148MHz. Mostly narrow band FM comms.
If the TV set used intercarrier for the sound, you wouldn't be able to tune in FM radio stations all that well. Oh, if two stations were 4.5MHz apart, you'd get some garbled mix of the two stations.
If the tuner was truely continious between 6 and 7, today it would be "cable ready"
Old 12-20-2011, 07:16 AM
Reece's Avatar
Reece Reece is offline
Rebadging home entertainment gear was done from the beginning of radio. Sears and Wards and others sold sets in the twenties with their names on them, made by others.
Reece
Old 12-20-2011, 11:32 PM
Einar72's Avatar
Einar72 Einar72 is offline
Chasin roundies since '79
Betcha it has split IF's
Old 12-20-2011, 11:55 PM
Nope! The 600 is intercarrier; 3 video IF stages followed by a detector with the sound taken off at second video amp, into 1 sound IF, ratio detector then amp to speaker. It does not tune the FM band, as it uses Hi band/Low band switching.
