Thread Tools | Display Modes |
I need your guy's help. need any technical info available for Viewpia LCD TV's
I would think, and I do hope that there's someone here who has access to some kind of technical information on Viewpia LCD TV's, particularly their 26 inch and larger models.
These TV's are sold over in the UK and europe, and they have a few things that can go wrong. Of particular interest to me is the failing to come out of standby, and the LED on the TV's front becoming very dim. I've searched on google for hours, and all i have found is people with questions, and no relevant answers. I'm also trying to figure out how to access the service menu on a Viewpia LCD TV. The EURAS database seems to hold some answers for me, but of course I can't access it. If anyone can provide me with any technical information, I would be very grateful. |
Also, even the worst new bad caps usually don't fail for at least a few months, these TV's could fail within a week. |
Check the surface-mount caps on the control board, SMD caps tend to get baked dry in LCD's. Also does this thing have a combo inverter/PSU board, or are they separate boards?
Sorry, but I need actual technical information on this brand. I would love to take guesses at what's failing and troubleshoot with test equipment, but time constraints prohibit me from doing this.
And yes, it has a combo invertor/PSU board, but again the power supply is fine. Once the chassis board is replaced with a known good one, the TV has no more issues. The power supply powers it just fine. The issue lies on the chassis board. Last edited by MRX37; 10-27-2009 at 05:50 AM. |
Does this set have a large IC on the control board with no pins sticking out of the side? If it does, these are called ball grid array chips. If you look under the IC you can see the tiny solder balls but nothing can get to them. The heat from the IC can cause the no lead solder to crack and cause many problems. I have inquired as to repairing these and gotten some wild suggestions. I tried a heat gun and it fried the chip. Another that worked was to put the board in an oven at 400 degrees for around 15 minutes and that is supposd to reflow the solder. It has actually worked about 30% of the time.
The biggest problem is melting the plastic connectors. ROHS.... designed with difficulty in mind! |
Well, ANY technical information I can find out about these TV's will be of great use to me.
I'll level with you guys... I know more about these Viewpia sets then most of their customers overseas do. I know because where I work sells what are essentially these same TV's, only with our logo and a different casing. I found out about Viewpia through a goof up where one of our TV's had the user guide for a Viewpia in it Now you would think we could just get all the technical info we needed straight from the manufacturer that makes these TV's for us... if you think that, you've never dealt with a Chinese TV manufacturer. Those assholes won't even give us the time of day, so we're on our own for technical info. Quote:
post pics of the boardset.
seems this set is sold under several names like spectroniq,ect
i collect and restore vintage radio's,tv's,and ham gear. email for more info |
This is the chassis board.
![]() The problem lies somewhere on this board. I just don't know where. |
Any ideas? Anyone?
With as many surface mount parts it has, you might have to replace the board. Those 'lytics could be changed easy enough but the rest is not so easy. Ever tried hand soldering SMPs? Not fun at all.
The chips are impossible when the pins are so close together that there's only about .10 of an inch between them. There probably is a bad chip there somewhere too. Usually what goes on this kind of stuff. I guess in other words, check and replace what you can without wasting too much money on it. Good luck with it.
My TV page and YouTube channel Kyocera R-661, Yamaha RX-V2200 National Panasonic SA-5800 Sansui 1000a, 1000, SAX-200, 5050, 9090DB, 881, SR-636, SC-3000, AT-20 Pioneer SX-939, ER-420, SM-B201 Motorola SK77W-2Z tube console McIntosh MC2205, C26 Last edited by zenithfan1; 10-29-2009 at 03:28 PM. |
I also found out today that these TVs are also sold by Pyle. |
Just reviewed the entire thread.
You state - Country of origin - China Sets fail within a week Hundreds of sets affected OK - I'll be a smart a** - why bother with them??? Even if you were able to solve this particular problem, the re-failure rate of these sets has to be astronomically high. |
I know they're crap. There's nothing i can do about it except try to track down the causes of failure. |
