Old 07-01-2009, 05:51 AM
AndrewM AndrewM is offline
Philips Australia Colour TV range
With some recent acquisitions, I've been able to assemble enough sets to provide a gallery on early Australian Philips colour televisions. I apologise in advance for the less than ideal camera angles and other issues, but the sets are all in storage at the moment until I have an area to display them.
In preparation for the commencement of official colour broadcasting in 1975 Philips Australia released its first colour TV sets in 1974 using a modified version of the European Philips K9 chassis. The Australian chassis was called the K9A. The main difference was the adoption of a rotary VHF only tuner instead of the varactor tuner normally fitted. This was because at the time, we did not have a UHF service in Australia and our VHF band extended into the FM broadcast frequencies which required a unique tuner.
The initial range consisted of 4 sets and I'm fortunate to have 3 of the 4.
The first set was a 22" table set, model number 02KD254. I don't have this set yet, but it would look the same as its bigger brother, the 26" 02KD654 (first picture).
The two remaining sets of the range were the high end 26" console models, 02KD684 (second picture) and 02KD694 (third picture). I have not seen the speakers used in the KD694 as they are in a sealed enclosure.
By the following year (1975) a UHF broadcast service had been allocated (but did not begin until a few years later) so it became viable to develop an Australian version of the varactor tuner. This allowed the Australian sets to return to the original European design with push button tuning. This chassis was designated the K9A-2. This new range had been reduced to three sets, the 22" 02KD255 (which I don't have) and the two 26" sets, the 02KD655 (fourth picture) and the 02KD685 console (fifth picture - this set is currently missing its legs). The KD694 was dropped after the first year, I suspect due to poor sales as it was very expensive.
This last picture is of the K9A-2 chassis. This is a delta gun CRT chassis using either a A66-140X or the quick heat version A66-410X CRT's (26" models). For those not familiar with this chassis, the silver cans on the smaller panel contain plugin circuit modules. They were designed to be easily replaced and disposable (but were usually repaired). The power supply lives in the cage in the middle bottom of the case. It is a switchmode design, but the chassis is not live as the metal framework is tied to earth via the power lead.
