Old 03-27-2009, 02:18 AM
AUdubon5425's Avatar
DTV & Bad Weather
Well, I've been experiencing some very severe weather for a couple of hours now. This is the first time I've been able to witness what a DTV OTA signal would look like during high winds and severe thunderstorms.
I am using rabbit ears, which have pulled in strong signals with no problems. Well, as soon as the thunderstorms hit the DTV signal went to absolute crap. I'm very disappointed, and thankful I still have analog to fall back on during this flooding and tornadic activity.
It really surprised me how bad the signal deteriorated, considering I'm less than two miles from the transmitter tower of the station.
Thank God we still have power - I've had a fever for 3 days and am having to stay up to monitor the flooding.
Old 03-27-2009, 06:59 AM
compucat's Avatar
compucat compucat is offline
1949 Motorola 9VT1
DTV signals are very fragile and can deteriorate at the slightest change in weather. I too use OTA DTV with amplified rabbit ears and the signal breaks up if it is just raining bad enough. In emergencies, turn to AM radio.
Old 03-27-2009, 10:40 AM
MRX37 MRX37 is offline
I have to take issue with this, as when I got my DTV card, I did all kinds of signal strength tests. I even have a thread about it on here somewhere.
With a decent rooftop antenna, I can receive DTV well enough for emergencies in rain, snow, and fairly high winds. Winds I can't really test because my antenna isn't anchored well enough.
Still, I agree that analog is better for emergency usage.
At least we still have AM and FM radio.
Old 03-27-2009, 07:17 AM
batterymaker's Avatar
Repro Battery Builder
And the industry says DTV's an improvement. <<snort>>
Old 03-27-2009, 07:45 AM
zenith2134's Avatar
Still hoping they increase transmitter power after June 12...I mean, people are going to need OTA television, right?!
Old 03-27-2009, 10:02 AM
I have acquired an outdoor antenna and mast - it should be around 12-15 feet off the ground. I'm hoping that once I install that it will help, but I am now having my doubts.
I do have WeatherRadios and plenty of transistor sets. What's nice about seeing the radar for yourself is that many of the local meteorologists are not entirely familiar with the area and rely on the Super Duper Doppler 99000, which sometimes has place names in the wrong neighborhood or seem to invent their own.
Old 03-27-2009, 05:52 PM
OvenMaster's Avatar
DTV blows
Mine's amplified and 25 feet off the ground. I lose CBS totally when the trees are in full leaf, and anything else that's more than 15 miles away when there's rain and/or wind. The CBS affiliate is supposed to be putting a DTV transmitter within 5 miles of my location instead of its present 25miles away(!).
Tom
Old 03-27-2009, 10:04 AM
000
Old 03-27-2009, 10:13 AM
Just another reason-as if we needed more-to DESPISE the trainwreck that our TV system has, or will, become.
Old 03-27-2009, 10:15 AM
Ohighway's Avatar
Ohighway Ohighway is offline
I posted somewhere else on the forum about my experiences with OTA DTV. My experience with the signal was that it was very susceptible to weather and particularly in my case....susceptible to aircraft flying overhead. It would just wreck the signal.
Rabbit ears were next to useless with my DTV converter box. However, I did pick up a cheap amplified antenna from solidsignal.com It was a DX brand "Active 5" antenna and was (and still is) priced under $18, and in my case took $11 to ship. For just under $30 it made a huge difference.... and I only had it mounted in the room where my TV was. Mounted outside or even in my attic would have made even more improvements. The unit comes with a control box and remote so you can electronically "point" the antenna in 12 different directions (every 45 degrees) to optimize the signal. It works for analog and digital. (not sure about FM)
Oh ... no affiliation with Solid Signal BTW. I just happened to purchase from them.
Console, chairside and table top radios. Test equipment , tubes, and a couple TV's. Oh, and tube/SS audio equipment.... lots and lots of audio equipment.....
Old 03-27-2009, 11:58 AM
gearhead's Avatar
gearhead gearhead is offline
AK Member
Just out of curiosity, how far away from the broadcasting are are you?
**your witty remark here for just pennies a day!!!**
Old 03-27-2009, 12:14 PM
Ohighway's Avatar
I'm 20 miles West of Baltimore, and I'm North of Washington DC by about..... 30 miles I'd guess. There were only a handful of analog stations that I got really well. DTV was even worse as it seems an "all or nothing" proposition .... and using rabbit ears, -mostly- nothing. The amplified antenna helped a lot. Still didn't protect me from the effects of planes flying overhead though.
Just as luck would have it.... a couple months after I geared up for OTA DTV, Verizon ----finally---- came through our neighborhood to install FIOS. As we really wanted the internet access we got that, and getting the TV wasn't that much more. So for now the OTA DTV hardware sits unused.
Old 03-27-2009, 05:31 PM
gearhead's Avatar
AK Member
My gf is looking for something that would work indoors 15-20 miles away.
That sounds like it could be worth a try.
At least the price is easy to take.
Old 03-27-2009, 06:01 PM
Ohighway's Avatar
I thought it was decent for the money. It also has a button on the remote to kill the amplified portion for stations that are real close.....
Old 03-27-2009, 11:34 AM
merrylander's Avatar
merrylander merrylander is offline
Every 'expert' has gone totally nuts over anything digital. We converted from analog to digital in the telephone network simply to improve the signal to noise ratio. That is because a digital repeater (fancy amplifier) only needs to be able to distinguish ones and zeros and the re-create the bit stream out the other side at higher levels. With an analog amplifier everything gets amplified, both the voice signal and the noise. The difference is that we mostly transmitted over wires or optical fiber. Signals were also sent by radio waves but with very directive antennae and even then they did suffer weather effects.
"Don't you love farce"
Some people are like Slinkies, not really good for anything. They do bring a smile to your face when you push them down the stairs.
