Old 01-11-2010, 09:47 AM
veg-o-matic's Avatar
veg-o-matic veg-o-matic is offline
Huh?
The Sears is back
Been organizing the house lately and it turns out I made room to put another TV set, so I decided to drag out the old Sears (by Sanyo) that I got several years back. I hadn't powered it up in at least three years, so I thought I'd just display it and not use it. Then I decided that since I have two of those newfangled digital adaptors, I'd hook one up and see what happened.
Wellsir, the thing powered up with a monochrome picture but after a few minutes, color popped in. Not a bad pic, either, though it definitely needs to have the convergence done (which I'm probably not going to mess with.)
There was a terrible buzz in the audio whenever text appeared on the screen, but a little fiddling with the AGC lessened the problem.
On to the pics! Here's a bad one (I forgot to turn off the flash), but it gives you a look at the set itself
