Old 11-30-2008, 12:57 PM
radotvguy radotvguy is offline
mike g
magnavox help
Well i usually only work on old tube radios and tvs , however my brother gave my a newer tv to fix . Anyhow its a maganavox model number no #25TR12 C 102 . chassis no # 25p606-00aa . Tv is dead, and the fuse is good , as cord good as well . Check fuse and components in that area which seem to be ok . Anyhow after poking around a bit i found R432 burnt open , i do not know the value of it and its toasted and unreadable . I am working without a schematic and probably should order one however i dont want to invest too much into this set . Its from 1995 . Anyone know the value of R432 and does anyone know of this type of issue with this set . Any help would be gladly appreciated .
Old 11-30-2008, 05:30 PM
rcaman's Avatar
rcaman rcaman is offline
r432 is 1k ohm. there is a str30130 regulator that needs changing and the 100mfd @ 200v behind the flyback. steve
Old 12-01-2008, 07:28 PM
mike g
magnavox
would anyone know the part number to Q400
Old 12-02-2008, 01:41 PM
rcaman's Avatar
q400 i always use nte198 c432 is the location of the 100mfd cap. you need to see if the horiz output is shorted also. steve
Old 12-02-2008, 01:59 PM
If the HOT is shorted, there is a small fuse that's soldered to the PC board that's probably open. It does not look like a fuse and is about the size of a diode. I think it's location number is F401.
Old 12-02-2008, 03:04 PM
mike g
thanks guys, i have the rugulator, capacitor and resister on its way from moyers . I will check the HOT tonight . Q400 did not seem to test good and i might just go ahead and replace it . However i tested it in circuit and didnt remove it .
Old 12-04-2008, 08:25 AM
rcaman's Avatar
if it didnt check shorted it probley ok. those are good chassis. steve
Old 12-04-2008, 10:22 AM
mike g
the regulator , resister and capacitor came in last night . I will be installing them in tonight and check the other two transisters as well .
thanks for the help
mike
Old 12-05-2008, 09:27 AM
mike g
Well i installed the regulator,resister and capacitor last night . Then tested q400 and HOT ,which tested good out of circuit, then reinstalled into circuit . Firied it up and its a runner !!!!!!!
thanks for all the help from my fellow AK members
thanks guys
Old 12-08-2008, 03:27 AM
freakaftr8's Avatar
Convergence freak!
Thats awesome! Always good to see an operating set
