Old 07-29-2007, 03:18 PM
yagosaga's Avatar
yagosaga yagosaga is offline
VK Member
First solid state color tv set
Hello,
please can you tell me which brand and chassis was the first solid state color tv set in the U.S.?
- Eckhard
Old 07-29-2007, 07:46 PM
Old 07-29-2007, 08:53 PM
I don't know if it was first overall but there was the RCA CTC-40 chassis in what, 1969 or so? also the RCA 2000.
Old 07-30-2007, 01:18 AM
kx250rider's Avatar
REAL TVs have TUBES!
I think it was the Motorola.. I used to think it was the 1968 RCA CTC-47 in the G-2000, which actually predated the CTC-40. Not sure why they did that. In fact, the CTC-40 has a 3A3 in it. Magnavox had an early SS set too. Zenith, as usual, was late with theirs in '72 with the 25DC56.
Charles
Old 07-30-2007, 08:23 AM
roundscreen roundscreen is offline
My guess would be the 1969 RCA G2000 had the first 100% solid state chassis.
The ctc 47 had a quadrupler for the hi voltage instead of a rectifier tube.
The Motorola was the first with a solid state chassis but still had a rectifier tube for the high voltage. If you need the model #s, I can post them for you.
Ed
Old 07-30-2007, 11:30 AM
Aside from the rectifier the Motorola certainly won...when did they start using those solid state plug-in rectifiers? I'm pretty sure Sylvania had a solid state set on the market before the sixties were out but after the RCA.
Old 07-30-2007, 07:24 PM
GE also made a solid state high voltage rectifier. It was a big black thing that sorta looked like a tube. I pulled one out of a rca set thinking it was the wrong part.
Ed
Old 07-30-2007, 12:44 PM
Old 07-30-2007, 03:41 PM
yagosaga's Avatar
VK Member
Thanks for all replies. I have asked because in Europe, the East German "Color20", made in 1969, was recognized as the first solid state color tv set. But as far as I know, the Motorola Quasar had to be the earlier solid state color tv set.
Every detailed information is wellcome!
- Eckhard
Old 07-30-2007, 07:16 PM
- Eckhard
The model # on the RCA G2000 is G2000, Must have been a big deal in 1969 cause it really does have a nice picture. Some 38 years later, I am finding some really strange problems with the ctc 47 chassis. The silver foil caps are all bad and I had to replace them. 300 something pounds of trouble, But still worth it.
The Motorola model # is WL852EW and the chassis # is TS915. {Works in the drawer} Now here the interesting part on the motorola. The one I own is made in 1968 and I could swear that motorola made a solid state works in the drawer in 1966. IIRC I had repaired one in the 80's and thought it was made 66. Do any of the guys here have a works in the drawer made in 1966?
Could be I am wrong.
When I was a kid I thought the TV ads for the works in the drawer where so cool. I wanted one in the 70s but could never afford one, But did find a broken one in the 80s and still have it.
The picture is weird because I am still working on the 2000 and can not move it. Not to mention that I have the 2000 ripped apart.
Ed
Old 07-31-2007, 12:05 PM
kx250rider's Avatar
I believe the same. I have heard that from more than one source, but I can't prove it.
Just to confirm; isn't the G-2000 a 1968 model? I have the book on it. I'll check.
Charles
Old 07-31-2007, 06:38 PM
Charles
I took a look at my service manual and the copyright date is 1969, Did they make the 2000 two years in a row? {Interesting}
I have three 1968 color sets, The Motorola, A zenith and a Magnavox combo.
It would be really cool if the 2000 is a 1968 since I have a 68 collection going already.
Ed
Old 09-15-2007, 01:27 PM
RaymondLeggs RaymondLeggs is offline
Banned
Ed
Nice TV's at least the CRT hasn't started to slide or fall back into the Chassis yet!
Old 09-15-2007, 04:37 PM
Thank you. The motorola has been a problem child, After running it about 20 hours it started having 2 white bars moving up from the bottom to the top of the screen.
I went and replaced all the electrolytics in the power supply and on the main chassis. And still, It did not correct the problem. After that I recaped and replaced all the panels in the set and Still it had the bars in the picture.
Then I got out the oscilloscope, Took a look at all the power supply voltages lines and could not see any ac in them.
When I went and took a look at the video signal you could see the bars running in the video signal. It was a strange picture on the scope, Kinda looked like a snake as it made its way through the video signal.
What I found was I had two leaky transistors on both of the video,agc panels I had replaced. After replacing the leaky transistors with nos transistors, The problem went away.
I had made the comment that the crt was crap, But I was wrong. This tv really has a nice clear picture. When I get the time I will remove the safety glass on the crt, Clean off the glue, And reinstall the glass to get rid of the yellow edges.
The problem with your crt falling back could be one of the mounts holding the crt in place is broken. Also I have seen sets where someone replace the crt and did not tighten the screws that hold the mounts to the inside of the bezel. If you take a close look at the crt from the back side with a flash light you should be able to see what is wrong. PLEASE be careful when working with a crt. It could go boom boom and hurt you.
What kind of set do you have and how old is it? Have you done repairs on vintage tvs before?
Ed
Old 07-30-2007, 10:24 PM
I'm far from an expert on the subject; my experience begins with the mid 70s stuff, but I do remember working on a few of those early works-in-a-drawer sets, and I always thought the oldest ones were made in '66. And my feeble memory is telling me that they did use a tube (3A3?) for the HV. And they were built like a battleship.
