CTC 17 find
2 Attachment(s)
I pulled this out of the shop that is close to Charlie. It has the 25AP22 crt. I do not think we have discussed this one here. It really has a nice cabinet. The controle layout appears to be the same as the CTC 16. The cataract will have to be fixed. I bought some Maple veneer to refinish the set. It was a survivor the hurricane! It was really scary being up in that building. Some of the wood holding up the rafters was at strange angles. I was able to pull another pickup load out of there. I hope to go back soon before the shop is torn down. The building is slated to be torn down. It was already in bad shape but the storm did it in.
On the right with the back off is a Sylvania roundie set. It has the same chassis as the one I restored that cabinet for. I will post pick of that later. polaraman |
AWESOME early rectangular color set, isn't this first or second chassis with this type CRT??? 1966, 1967??
IIRC, CTC-17 was a modified '16 for rectangulars. One of RCA's first...
IMHO, the '16's a great set, but it misses on lack of automagic chroma gain and automagic fine tunning. Did any roundies have automagic fine tunning? I know Zenith always had the auto chroma gain... Why did AFT take so long to happen anyway, and who was the first? |
I think the first RCA with AFT was the CTC-30. It is kind of a pain as it is a "pull out to disable" feature on the lamp dimmer knob and always activates when the control door is closed, however the AFT on this set seems to actually mis-tune it from optimum. There was a late model Philco round set which was a tube-transistor hybrid around 1969 which may have had AFT.
No RCA roundies had AFT as far as I know. Some of the later "three if" chassis rectangular sets did though. It was a little chassis that mounted next to the IF strip. It probably wouldnt be too bad to put in if you were building a set from parts.... The tuner has to be for AFT also.
Polaraman- Is that a ctc17x by any chance? I've read that they had an improved blanking circuit, using a transistor and powered from the voltage divider on the Horizontal output tube supressor grid. When you get around to restoring this, and if your set has it, could you post a pic of that circuit? I'd like to see where and how they built it into the chassis. Should be the only transistor hanging under there. John |
I will have to clean the chassis soon. It looks to be CTC 17AE. That would be SAMS 779-3. I will look for the transistor. The set will be restored. I needed it for the CTC collection. I have the following numbers off the top of me head. (9,11,15,16,17,19,22,28,31,39,52,54,55)
polaraman |
Is that ctc-39 the 23" or 25" version?
Chad,
The CTC 39 is a 23" set. The flyback and picture tube was shot. It is tops on my list to finish repairs. polaraman |
I have a CTC-21 combo from 1967 and it has AFT. That is the earliest one by RCA as far as I know. Also, the CTC-27 sets in my collection have it as well.
| All times are GMT -5. The time now is 08:06 PM. |
