-   Rectangular Screen Tube Televisions (http://www.videokarma.org/forumdisplay.php?f=45)
-   -   Zenith 19EC13 - Smoke and bad smells (http://www.videokarma.org/showthread.php?t=53729)
RetroHacker 12-05-2005 07:56 PM
Whilest working my way through cleaning my garage (I would _love_ to actually get a car in there before the snow gets bad), I ran across this Zenith. I'd picked it up a while back, and never had a chance to try it. So, I checked for obvious bad stuff, and plugged it in. Sound came up instantly, but no picture. I don't appear to be getting high voltage, although I might have gotten a quick burst of it because I coulda swore I felt a little static on the tube. I let it run for a minute and I smelled something that smelled like a burning resistor. I unplugged it and did more investigating. Under the chassis, I found that the components connected to the 6DT3 damper tube were crispy and burnt - notably a couple disc capacitors. Now, this seems like the sort of problem where replacing those caps is just going to result in more burnt parts. Those ceramic discs are pretty reliable, they ougt not burn. I know there are a lot of techs here that have worked on a lot of Zenith sets like this - so I figured I would check here before spending lots of time troubleshooting and tracking down parts. Anyone know what causes this in these sets?
Thanks!
-Ian
jpdylon 12-05-2005 10:37 PM
Shorted damper or HO tube. I would replace both as a precaution. The HV rectifier (if this set has a tube) may have a short as well. If the rectifier is SS, test it for leaks. I believe the early rectifiers were just huge diodes.
RetroHacker 12-05-2005 11:15 PM
That was one of the first things I thought of, but the HOT doesn't glow real bright or get too hot, and the damper checks out fine on the multimeter (yeah, different than actual circuit conditions, I know, but it's not a dead short at least). I'm not exactly sure where the HV rectifier _is_ in this set, the HV unit seems to be made up of several "things" - the flyback, and two other blocky stuffs. One of those must contain the HV rect.
I don't often work on sets like this, I do mostly older B&W sets or all-tube color sets. I rarely run across actual bad tubes, and I have a tube tester to aid in that. But my tube tester doesn't do compactrons, and I don't have any more tubes like the ones in this set - so... I was hoping that this was another one of those real simple things that people would recognise as being a common problem in these Zeniths. Some obscure faulty resistor or something. Unfortunately, do to space and monetary constraints, this set is probably going to have to wait until I have more time and/or run across more parts. I'd like to have it working, but I have too much else I have to deal with at the moment (like getting the car in the garage). I also have a couple other sets that I am more interested in fixing - an RCA CTC-22 and a Zenith 25" tube color console.
Honestly, I do believe that the televisions are starting to own me - it's depressing, really. I have so much stuff and no room to work on it. And yet I'm still looking for more stuff - one of these days I'll find a roundie! Anyone else have those times where you wonder why you do it to yourself? Why do I obsessively bring home more electronics? Why when I have time to work on them, do I get so depressed at the disorder and lack of space and organization that I get overwhelmed and spend the day in front of a computer or sleeping? Gah, here I go again, rambling. Ugh, I'm depressed again now...
Poor little Zenith. One day...
-Ian
Adam 12-06-2005 01:11 AM
I have so much stuff and no room to work on it. And yet I'm still looking for more stuff - one of these days I'll find a roundie! ... Why do I obsessively bring home more electronics?
----This describes my life pretty well too.
andy 12-06-2005 01:15 AM
I would try replacing the caps first. About the only thing that will kill ceramic caps is a very large overvoltage which is unlikely to happen due to another failure. Pretty much any failure of the horizontal circuit will result in greatly reduced voltages. I have seen ceramic caps that failed and arced due to a defect in the cap.
jpdylon 12-06-2005 01:17 AM
Was this set one of the chromacolor hybrids? The chassis number seems familiar to me. The damper was a 6DT3? What's the HO? I may have spares you can have if you wish to pay shipping costs.
Sometimes a tester is not enough. It may test good in the tester, but under the real load is when the tube may falter.
If the set doesn't have an HV cage, it may have a SS HV rectifier, or it may even have a doubler or trippler.
If you can find someone here who has a sams or something, you could pull the HO and Damper tube and check the plate and grid voltages to make sure its not the tube at fault.
TVtommy 12-06-2005 01:31 AM
I'm pretty sure that set uses a tripler block. Replace all those caps under the damper. also replace damper socket if it has burned and carbonized between pins (or anywhere for that matter). This ain't the first Zenith I've seen do this. Replace burned resistors also. Check efficiency coil for burning/melting also. Go over this entire corner of the chassis good.
Chad Hauris 12-06-2005 06:45 PM
Also, I have seen horizontal output tubes destroyed because of an overload..even if you correct the circuit defect such as no oscillator output you go to put the HO tube back in and it doesn't work...you may want to test the output tube for shorts before putting it back in too...check the neg bias voltage on ho tube grid.
I always bring in more than I can work on at one time! too...but you really do need to get as many of these sets as you can NOW because say in 20 years they will be so rare you will be hard pressed to find one at a junk shop, estate sale, etc.
compucat 12-07-2005 07:52 AM
Once analog goes off the air which may be in 2007 now, many people will throw them out thinking they are obsolete never realizing a converter box can keep them functional indefinitely.
I always bring in more than I can work on at one time! too...but you really do need to get as many of these sets as you can NOW because say in 20 years they will be so rare you will be hard pressed to find one at a junk shop, estate sale, etc.[/QUOTE]
Chad Hauris 12-07-2005 09:48 PM
I think unfortunately most of the new sets of today will not be going when analog TV shuts down. (Properly repaired old TV's still will though of course). The number of less-than-10 year old TV sets discarded seems to be getting bigger each year. Have yet to see my first junked plasma screen but I know it's coming soon. Repair on those probably is a no go.
RetroHacker 12-07-2005 10:44 PM
I've seen junked plasma sets. Once the display portion gets damaged they're very, very useless. I thought about dragging it home and hanging it on the wall anyway - maybe I could get some kind of poster and put it in there, you know - and make it look like it's being used as artwork. Hehe, it's a funny thought, anyway.
-Ian
andy 12-07-2005 11:04 PM
I doubt many people will bother buying converter boxes for their analog TVs. Look at how many perfectly good non-cable ready TVs show up in the trash even though the cable company will let you use a cable box at little or no cost.
