The first "in-line" shadow mask picture tube
Who developed the first "in-line" shadow mask picture tube (I heard that "G.E.-Sylvania" did it)? Why they didn't use from the begining the "in-line" shadow mask.
that would be the 11sp22 in the ge portacolor
sylvania waited till the 70's to produce a similar tube that was compatible with the ge tubes. |
RCA came out with an in-line set that was about a 15" in the early 1970's...this was probably the second American brand to use in-line after the portacolors. I think Magnavox was next, in the mid-late 70's to use inline 17 and 19" tubes.
It seems like somehow it was difficult to set up the convergence on the early in-lines (many of the GE inlines even up through the 80's used a dynamic convergence system with convergence coils and pots that was simplifed from the delta gun tubes). The RCA and Mag. inlines were factory pre-set on convergence and used permanent magnet convergence components, like modern tubes. |
I always hated those RCA CRTs that used the non-adjustable permanent magnets for convergence. They always seemed to be a little off. Thomson still uses the same design. Even cheap Chinese TVs have adjustable convergence.
| All times are GMT -5. The time now is 03:10 PM. |
