| Aperna1985 |
11-28-2026 01:56 PM |
Question about replacing picture tube socket
I have a Zenith console set the chassis is a 12B14C50, when I found it it was knecked so I've been working on the chassis here and there trying to get it going before buying a picture tube. There was a lot of arcing inside the factory tube socket and it eventually fed back and actually blew out a few transistors in the chassis. I tracked down an original zenith picture tube socket. When I looked into the chassis to see what was involved in changing the whole socket, I saw that there's a lot of spots where there's multiple things attached to the wire. I don't want to go unsoldering clusters of things and cause a new problem lead me on a wild goose chase. Is there any negatives to just cutting the wires a few inches out of the chassis and soldering and heat shrinking the new socket to the existing wires? I would on solder and replace the focus lead 100% considering it deals with such high voltage.
