Panasonic NV-9400 Needs Love
This portable Umatic recorder was $20 at a computer show and it's seen a hard life but it's still all there. I have all the panels removed and soaking to try and remove a pretty quick and nasty paintjob it was given and spent some time cleaning the insides because it was stored somewhere really dirty. Was also able to locate the service manual.
Drum cleaned up. Tape path cleaned up, I had to delete the dew sensor because the plastic screws had shrunk and broken off in the base of the drum where I can't reach but now that it's cleaned and on the bench I can feed it a tape and confirm it mostly wants to work. Rewind seems happy but Fast Forward/Forward has a shrunken idler wheel and no longer grabs the takeup spindle. The belts are all there and have not decomposed but they are tired. I can insert a tape and press Forward and it will wrap the tape around the drum and the drum comes almost up to speed the but belts are just a little too stretched and the drum starts slipping while there's not enough torque left to unload the tape again automatically. Could try boiling them but even after cleaning the pulleys they are still reluctant. I'm not seeing any re-belting kits available, much less replacement idler wheels or a rebuild kit. How should I go servicing this? |
| All times are GMT -5. The time now is 03:21 PM. |
