Toshiba 27AF53 no vertical deflection
Someone asked me to check this Orion built Toshiba for them. They claimed it was working fine and then lost vertical deflection. The original LA78041 vertical IC was bad and there was a defective 100uf, 35V cap (measured 67 uf) in the circuit. All the pwer supply voltages were checked prior to changing these parts. I replaced the IC with an NTE7182 and the new IC went up as soon as I powered up the set. I have not gone any further with this set; as I was very disgusted when the new part went up in smoke. Does anyone have any ideas? I'm about ready to tell the owner to junk this set and move on to something else. The fact that it's built by Orion does not make me feel any better about it, either!
there is nothing wrong with orion built sets they have a good picture. why did you put an nte ic in there and not the original. i would put the original ic back in there that may solve your problem. i never use nte for horizontal or vertical deflection never. steve
On Sony;s, the NTE parts never work and you can almost never get away with subbing anything except the Sony part. How do they design em that way anyhow? Things like Jungle ICs, EEproms....
Hope you have better luck on this one. |
Well, I ordered an original IC and some fresh caps. I also replaced D402. It checked ok; but, a friend of mine who has a shop said it can check OK and still be defective. I was doing some more "parts checking" before firing up the set; and, found D403 and D410 to be shorted. They are both 28 volt, 1/2 watt zener diodes. I can't believe I forgot to check those earlier. I'll replace those and maybe this one will be fixed.
yea those zeners keep the supply suppressed to a "valid" level. might want to check the "dump off" resistor in that circuit to be sure it didnt open. (doubt it.)
It's fixed! One regular diode, 2 zener diodes, a vertical output IC, and some electrolytic caps got me back in business.
How's the picture quality?
Not too great at the moment but I have just a piece of wire on it for an antenna. I'm going to hook it to cable and see what it looks like.
OK, I hooked it to cable and it has a semi-decent picture; but, I've seen better. I've got a 2002 BOTL 25" Sanyo TV with a zillion hours on it that produces a better picture.
| All times are GMT -5. The time now is 06:15 AM. |
