Found a 13" Space Command Chromacolor II
1 Attachment(s)
thats a nice find. space command 100 is a single button remote, which operates the tuner only. If I remember correctly, you can select a channel as the "off" selecto. For example, channel 13 could be set to turn the tv off.
On a related subject...
I need a luminance module for a 13" ChromacolorII of the same era.
Nice set. Keep me in mind should you decide to part it out. |
carmine, I may have the module. Let me know the module number you need.
Re: Found . . . 13" SC Chromacolor II
andy,
I remember those sets. I don't like the design, however, for the simple reason that it is impossible to change channels if the power tuning mechanism is not working. Why Zenith did not design this model with a manual channel selector to back up the motor drive is beyond me. :dunno: This was unusual for Zenith, as most of their remote sets of that era with power tuning indeed did have a manual selector knob at the back of the set, so that the user could still operate the tuner if the power tuning drive was inoperative for any reason. The other drawback of this system, IMO, is that the automatic off function would not work either if the power tuning is itself defective (unless, of course, there was a manual on-off switch on the front panel). I agree as well with your statement that the drive gears between the power tuning motor and the tuner probably were stripped or broken if someone tried to turn the channel selector drum manually. I think this problem occurred quite frequently with these sets when the motor drive failed; people tried to turn the drum by hand, promptly damaging the gear train. Zenith's SC100 remote left a lot to be desired. This remote only allowed for one-way channel selection (and, of course, the auto-off function which could be set to trigger on any unused channel, not to mention channel skip for bypassing unused channels), but did not have mute or any of the other functions we now take for granted in today's IR remotes--such as complete home-theater control. (Magnavox had this, using ultrasonic control, in its high-end three-way entertainment centers of the '60s, but the control systems were mechanical nightmares comprised of very complicated mechanical drives, linkages and the like, not to mention the remote receiver itself with its own tubes and circuits. The system was set up to control TV tuning up/down, volume, mute, record changer operations and I don't know how many other control functions. My best guess is that, when these TVs got a few years on them and the remote systems began wearing out, the owners simply left them alone, as long as the TV and stereo still worked halfway decently.) Zenith's later Space Command remotes were much better, allowing for up/down channel selection (two-way drive), volume up/down/mute, motorized remote tint/color adjustments and other refinements. However, I think today's IR remotes operate even better than Zenith's best ultrasonic systems, with more functions than those early sets--and let us not forget, today's remote systems (and the TVs themselves, of course) have no tubes to short, get weak or burn out. I have an RCA RCU800-B universal remote which I have set up to operate my TV, VCR and stereo (all separate components), and it works great. The only thing I have yet to figure out is how to get it to operate the transport functions of my bookshelf system's dual cassette decks and AM/FM tuner scanning. (Ironically, it works just as it is supposed to with the system's CD player.) There must be an IR code I haven't discovered yet--back to the manual, I guess. There are about six or possibly more control codes for my Aiwa system, some of which I haven't tried yet--oh well, maybe I'll work on it tonight. Can't be that difficult to figure out. |
You're right, the IR remotes have more functions, but I still think the Zenith ultrasonic has great performance, especially the electronic transmitter type (do not have the mechanical transmitter). You can hold the hand unit in any position and the signal will get to the set. Distance sensitivity appears just as good as IR.
1 Attachment(s)
give me a model and chassis of your set. I might have a SM for it. If I can get a part no, I will contact moyer. They have lots of mechanical tv parts as well.
1 Attachment(s)
Yes, Andy, you're right--those small portables are very difficult to work on because of all the circuitry crammed into that small cabinet space. Portables, especially the early tube-powered and solid-state sets with small screens, in general are like that; I've seen many small sets that are even worse than your Zenith to work on (especially those small transistor portable TVs by Sony, Philco and the like; I hate to think of what it must have been like to work on the PC boards of Philco's Safari, for example, which was, I believe, one of the first all-solid-state TV sets to be sold in this country).
At 40+ pounds I wouldn't quite call the 13HC10 a portable. It seems more like a set that is put in one place and left there, or else put on a stand if the owner was interested in moving it from room to room, etc., like my RCA XL-100 or my Zenith Sentry 2. Both these sets weigh a ton and were not meant to be carried anywhere. However, I wouldn't want to be lugging a set like that around for any length of time. The Zenith Chromacolor and Chromacolor II series were good sets when they were new, and still are today if you can find one in working order, as yours seems to be (except for the slipping tuner drive gear). I have relatives who had a Zenith Chromacolor II console, with a modular chassis, in the '70s; the set worked well for them (with few if any repairs, IIRC) and had a beautiful picture on an antenna for over 20 years. If that doesn't speak well for the reliability of earlier Zenith products (when they were still made in Chicago and Zenith meant Zenith, not GS), I don't know what does. BTW, was I imagining things or did I see a coax cable connected (through a matching transformer) to your set's VHF antenna terminals--without a cable box? I noticed the channel selector was on channel 10, which is the NBC affiliate in Philadelphia. Were you running your cable directly to the TV, or is that coax from a standard outdoor antenna? |
Tuner rebuilding
You might try this guy, I had him rebuild a couple tuners for me.
http://qualitytuner.hypermart.net/stangle.htm#pagetop |
got your part!
1 Attachment(s)
Andy, you are in luck! I looked through my pile of zenith parts and I found the gear you need new in the bag! Part number 34-770-02. If you're still interested, give me $10 (shipping is included). Just let me know your address and it will be on its way.
| All times are GMT -5. The time now is 09:24 PM. |
