Old 01-24-2018, 10:16 AM
Winky Dink's Avatar
Winky Dink Winky Dink is offline
Zombie Tube Saga
In the course of my most recent project, the radio under test started sounding weird, then went silent. I found an accidental short which apparently killed my only 2A5. I tested the tube and found all to be OK except it showed zero transconductance. I rechecked the settings, retested, then tested on an emissions tester. Same result. Zero emissions. So I set it aside.
In the next few days I acquired three used 2A5's. Two tested OK, but the third showed a heater/cathode short on the transconductance tester. Retest after a five-minute warm up gave the same result on both testers. So I set it aside.
Four days, before tossing the cathode/heater short tube, I decided to check it again. I put in the tester, turned it on, and forgot about it. A hour later I looked at it, and it showed no leak, no short, and excellent transconductance. So, it was a self-healing tube. Probably got something on the cathode or heater which took a while to burn off.
Then I thought, what the heck, I'll retest the dead tube. Son of a gun, it was normal too. This was good fortune, but also eerie. How did it come back from the dead?
Now that it's a Zombie Tube, how do I keep my other tubes safe?
Winky Dink
Damn the patina,
Full speed ahead!
Old 01-24-2018, 12:01 PM
N2IXK's Avatar
N2IXK N2IXK is offline
Technohippie
A tube with low emission coming back to life after being heated for a while is quite common. It does seem to be some kind of contamination being cleaned off a long-dormant cathode coating. This is especially common with CRTs.
The H-K short going away is more unusual, and I would be worried about it coming back. Try banging the tube around a bit while testing to see if you have an intermittent.
Old 01-24-2018, 12:15 PM
Winky Dink's Avatar
I do rattle tubes when testing them. These two seemed OK, but I put them away with a note about their history.
Winky Dink
Damn the patina,
Full speed ahead!
Old 01-24-2018, 09:12 PM
MadMan's Avatar
MadMan MadMan is offline
The Resident Brony
Just keep it away from any fresh brains, you should be fine.
Old 01-24-2018, 09:41 PM
I'm trying to remember, if Zombies are the ones that don't have a reflection.
Good old days of the Friday evening horror movies on TV.
Old 01-24-2018, 10:03 PM
Popester's Avatar
Popester Popester is offline
It was Dracula that wouldn't have a reflection from a mirror. Also Dracula hissed and howled when a crucifix was shown in his face lol.
My wish list:
Sony KV-7010U
Sony KV-1220U
