Old 09-21-2017, 09:25 PM
TUD1's Avatar
TUD1 TUD1 is offline
TheUniversalDave1
My new Zenith 20YIC50
Got this set this weekend along with the CTC-15, but just now got around to putting it back together. The picture tube is marginal, but it will make a decent picture. The high voltage however, is out of control. When I measured it, it was at 41 KV! I tried adjusting it, but the stupid control would not move. It's the kind that you have to stick a pencil eraser or something in to adjust. I don't like it a bit. I'm just going to keep the brightness cranked, so hopefully it will keep the HV down around 30 KV, and it won't destroy the tube. I think this set uses those darn varistors, so that's probably what's wrong with it.
"If you wish to make an apple pie from scratch, you must first invent the universe." -Carl Sagan
Old 09-21-2017, 10:40 PM
MadMan's Avatar
MadMan MadMan is offline
The Resident Brony
Decent looking set.
Old 09-21-2017, 10:54 PM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
Old 09-21-2017, 11:14 PM
TUD1's Avatar
TheUniversalDave1
I was able to adjust the control and get the HV down to about 35 KV with a dark screen.
Old 09-21-2017, 11:34 PM
maxhifi's Avatar
maxhifi maxhifi is offline
Those color bars look great. Are you absolutely sure your high voltage probe is accurate? I know mine always reads low.
Old 09-21-2017, 11:35 PM
mrjukebox160 mrjukebox160 is offline
Still very high. Could be the 6HV5.
Old 09-21-2017, 11:37 PM
You sure that HV probe is calibrated right? 40KV is awful high for a tube type HV supply. No-load, unregulated shouldn't go much over 32-33 KV if that.
Old 09-21-2017, 11:42 PM
Jon A.'s Avatar
Old 09-22-2017, 01:11 AM
TUD1's Avatar
TheUniversalDave1
I toggle between saying "twenty-why-one-see-fifty" and "twenty-why-eye-see-fifty." Saying the latter is quick and easy. This is the 21st century after all. Quick and easy is king nowadays.
I'll get the schematic out later and see if we can find that stupid varistor.
Old 09-22-2017, 01:29 AM
Jon A.'s Avatar
Old 09-22-2017, 07:43 AM
Doug did testing & found a modern sub for the thermistor. It here
somewheres. Trouble has been the OEM's are going bad in the
package.
Keep in mind always check the tube chart for the right damper / regulator
tubes & do not sub a wrong pair.
Old 09-22-2017, 08:29 AM
Here is some good reading on trouble shooting the Zenith Pulse regulator circuit:
http://videokarma.org/showpost.php?p...5&postcount=22
I believe this is doug's thread on VDR replacement.
http://videokarma.org/showthread.php...ght=Zenith+VDR
Old 09-22-2017, 11:20 AM
TUD1's Avatar
TheUniversalDave1
Doug showed me agood replacement for the varistor on the FB page.
Old 09-22-2017, 11:57 AM
TUD1's Avatar
TheUniversalDave1
Here's the offending part on the schematic.
Old 09-22-2017, 01:06 PM
Save your old Varistor if possible - I'd like to have it, to investigate the failure curve.
When Doug did his experiment(s), I took to my own Zenith Varistor stash to see if I had any that had failed. Of 9 unused/NOS, all 9 were good. Of 7 pulls from various chassis, and some identified only by comparing the body color markings to NOS ones, I was able to see only one failure - a beige/purple striped Varistor that was open - no response all the way to 1KV.
Silicon Carbide Varistors (what Zenith and other TVs used) have a different V/I curve than the semiconductor MOVs Doug used. The SiC varistors all have a linear V/I curve, and like MOVs, they are rated by "some voltage at some current" with the most prevalent current being 1mA. So if a SiC varistor is rated at 400V @1mA, applying 400V DC to the varistor in a closed circuit will yield 1mA of current flowing. Some Zenith varistors are rated to 950V, not a problem for me to measure with a Fluke 332D 0-1000VDC (okay, only 999.999V) voltage standard with a current compliance to 20mA, plenty of room for varistor testing.
About 4 years ago, I got a Zenith 800-600 Zenith Varistor/Thermistor kit with 90% of the varistors being new, unused. All had good V/I measurements. My workman stash got raided as well, with only one (used, solder on leads) varistor being w-a-a-y out, topping at 560V for a 410V varistor.
If you wanna try an original, lemme know what you have, and I'll send you a NOS one, free, if I have one - and verified good.
USN RET (Avionics / Cal)
