Old 06-08-2017, 04:35 PM
StellarTV's Avatar
StellarTV StellarTV is offline
RCA NOS Inventory
Hi Everyone,
I recently bought a bunch of inventory from an old RCA distributor which has been out of business since the 80s. Most of the parts are for 60s and 70s color.
Below is a partial list, I've had to hire periodic help to get everything inventoried and I'm not through yet. When I get the list complete I'll post an addendum to this (and delete this part of the message.) I kindly request that you please not inquire about parts not listed because I simply won't know until the rest of the stuff is inventoried. PM me for prices which will include postage to the continental US. Some boxes have been opened but I otherwise guarantee the part is new (no solder on flyback lugs and stuff like that.) Thanks!
133101 power cord
133101
136669 yoke
132666 antenna block
134027 motor
136669 yoke
141853 shaft w/ gear
141194 tuner
141462 crt socket harness complete
145445 crt socket harness complete
126384 anode connector
141485 transformer
150043 transformer
144256 motor
154518 transformer
141788 vhf dial
119452 Shaft 3.810” L
141507 bracket detent assy
141604 Module MCM001A
116554 transformer
141562 circuit
145796 coil adjustable
144493 lever audio slide
117426 transformer
145716 tripler
141574 circuit aux control
132584 delay MAL001A
141388 wire kine mounting
141409 connector molded w cable
112828 Capacitor 60/30/20
145728 circuit
140759 krk-214d tuner
132634 quadrupler
132634 quadrupler
132375 transformer
141485 transformer
141474 circuit pw500 deflection
141500 dial assembly
141466 transformer input reactor
114003 transformer band pass slug tuned
145791 IC MN1405VT
141782 Extractor module x5
141832 Resistor var comp
141919 socket molded
141875 capacitor
140836 knob fine tuning
114303 transformer band pass slug tuned
141665 transducer
141920 socket molded
141611 IC
141573 IC
141594 switch
141649 selector knob
145732 capacitor
141520 shaft
141671 IC SPS-2867
136976 yoke
132962 transformer
132962 transformer
133743 Resistor 500 250k 10k switches
126435 Coil 8-1.4 mh slug tuned
114639 holder
114639 holder
144444 holder
140968 Capacitor 4 section alum elect
6333 15-85 mh horiz. Osc
133525 resistor
132643 bar control
132540 module horizontal osc. Mah002a
133525 resistor
140968 n/a
140958 tuner complete krk226a
132583 module chroma mac001a
132755 knob
133525 resistor
141341 breaker
144218 spindle
133008 resistor
145612 coil
133008 resistor
114650 magnet blue lateral
133525 n/a
133144 module demodulator accutint mas002a
133008 resistor
122525 resistor
133008 resistor
144307 circuit leaf switch
144443 holder vxa0784
140868 n/a
144218 spindle
(10)144906 spring
140779 knob
144916 circuit
141407 switch remote master console
140780 dial vhf
132878 switch s.p.s.i rocket-slider
133908 cap
133908 cap
144218 spindle vxr0065
140912 knob fine tune
144169 circuit sensor
144916 circuit vek0517
132956 res. Var. 100,000 ohm 30%
133908 cap
(10) 144554 clamp lead small
133908 cap
140911 knob
140836 knob
144240 holder
132643 bar control
144420 brake vxz0049
145612 coil
133908 cap
144420 brake
141383 resistor light
140911 knob
141407 switch master on/off
141420 coil adjustable 35.75 khz
133270 switch push button
107538 coil rf filter
323-0033 var. control h.b.l. 2 v.r.g amp
76-10982-2 magnecore antenna
145299 resistor
32-4738-1 I.F. Transformer
32-4738-11 1st I.F Transformer
176912 magnet kit
144729 magnet centering
140067 module pm200A
141290 I.C
32-4738-12 2nd I.F Transformer
144364 arm impedance
12-H1 255-270 KC Input Perm. Tuned I.F
12-C2 455 KC I.F Output Trans
6210 TV Sync. Stabilizer ringing coil
106841 Connector 12 contact male
30-6035-5 RC Network
6211 16-42 mh tapped sync stabilizor
13-PH1 printed circuit 262 KC Input I.F
30-6536-5 RC Network
4624 15 Microh'y 300 MA R.F choke
18A751494 n/a
13-PC1 455 KC Input I.F Printed Circuit
30-6546-1 RC Network
109835 circuit breaker
106874 Connector 12 contact female
138123 circuit breaker hold 2.5 A Break 4.00 A
115329 Stylus Dual Saphire Turnover Assy
152073 capacitor
SK3289 IC Chroma Processor
SK3290 IC Chroma Demodulator
145744 Anode cup and clip replacement
Magnus Rubsam
Stellar Vintage Electronics of California
CRTs, Restorations, Chassis, and Color Conversions
Old 06-09-2017, 10:13 PM
Looks like you got some Philco, Sylvania and Motorola stuff too. Couple of Miller part numbers in the list too.
Looks like lots of XL100 and Colortrack parts - bulk of the RCA stuff is for sets from 1972 to 1983ish. All the sets of my younger years.....
126/127 prefixed stuff is about the time of the CTC40/44 stuff.
13XXXX is almost always XL100
14XXXX parts are almost always Colortrak...
Without an RCA cross guide, can you also list the type (Vert, Power, Flyback, IF...) of transformer?
I wish my RCA mentor at Cain Electronics was still around - SHE had intimate knowledge of RCA parts and had encyclopedic knowledge of RCA part-to-chassis info. She used to amaze me with the "name a part" and she could tell you what it was - 99% of the time. Intimidating, but she shared her knowledge willingly. Of course, she'd order $10K of RCA stuff every other month, so she had to know.
The only other RCA guru I know is still in the business at PriestCain in Norfolk. He worked for Priest in the 70s/80s when they sold RCA and RCA SK stuff.
USN RET (Avionics / Cal)
Old 06-11-2017, 07:47 PM
StellarTV's Avatar
There are definitely a few 80s parts here. All of the descriptions are basically verbatim as listed on each carton. Flybacks are generally only labelled "Transformer" with a couple of exceptions. There are some CTC-15 or so era flys here.
I'm not really geared to go back through all of this stuff for a more accurate description, and what I have listed so far was done via hired help. I can definitely try to get a better idea of what a particular part is if someone inquires... most of what's listed "Transformer" is a flyback. I don't remember seeing any power transformers.
I'm hoping that anyone who needs a part will have a service manual, or at very least a Sams at their disposal. It may not all be the most desirable stuff, but it certainly deserved to be saved and made available.
Magnus Rubsam
Old 06-12-2017, 06:35 AM
Originally Posted by StellarTV View Post
....it certainly deserved to be saved and made available.
AMEN!
Too often short-sighted folks dump stuff that is greatly needed elsewhere - tv parts, old test equipment parts, old car parts/re-build-able cores and even old computer memory SIMMs - not every computer got updated when MS released the latest Windows build. I sold some old 4 Meg SIMMs to a machine shop for one of their CNC machines....built in 1993.
Even worse is the hoarder that knows not what he/she has, or won't part with it....
Thread Tools
Display Modes
