Old 05-19-2017, 09:26 AM
dtvmcdonald's Avatar
Wanted: MHD4 British tube
I need a British very old tube, an MHD4. This is essentially a 4AV6 ( a 4 volt 6AV6)
in a large "G" bulb (with the tiered top) and a 7 pin base not like any American tube.
I have not yet found one in Britain.
Alternatively ... does anybody have one of those standard British 7 pin bases,
a broken tube will do. I could use a 4AV6 but don't want to smash the bad tube.
Yes, its a radio tube used in a (1936) TV, since its AM sound.
The sound is just like the 4 signal tubes of a BCB radio except for the
1.5 MHz IF frequency and the oscillator tunes 49.5 to 40.5 MHz.
Doug McDonald
Champaign IL 61822
Old 05-19-2017, 02:47 PM
N2IXK's Avatar
N2IXK N2IXK is offline
Technohippie
Is $18 too much to spend on one?
http://www.vivatubes.com/marconi-eng...g-vacuum-tube/
Have bought a few tubes from that vendor in the past, with no issues, FWIW.
Old 05-19-2017, 05:15 PM
For that price I expect some test. I had no difficulty testing mine,
which tested good but a heater-cathode short.
Old 05-21-2017, 05:07 PM
miniman82's Avatar
First Light: 1952-2011
Put a brightener on it
Evolution...
Old 05-21-2017, 05:30 PM
benman94's Avatar
benman94 benman94 is offline
Resident Lunatic
MHD4? Probably series string. Less effort to just find a good tube.
Old 05-21-2017, 11:09 PM
Penthode's Avatar
Penthode Penthode is offline
4 volt ac was the British standard pre-war filament voltage for AC sets and a parallel filament string.
Old 05-22-2017, 10:28 AM
baursam's Avatar
baursam baursam is offline
Ask seller if they can test/ship
http://www.ebay.co.uk/itm/THE-marcon...-/262983829774
Or tested unsold probably due to the category it was placed in!!
http://www.ebay.ca/itm/MARCONI-MHD4-...8AAOSwrhBZA0bt
Old 05-22-2017, 09:36 PM
baursam's Avatar
Also, here's a cross reference chart, Mullard is the only other match.
http://www.6v6.co.uk/vcomp/valve_xref/british_1930s.htm
And here's a match
http://www.mullardmagic.co.uk/mhd4met-osram-nib
Old 05-23-2017, 08:47 PM
I'm getting one, pig in a poke.
A brightener won't help. The tube works but has an
intermittent heater-cathode short.
Old 05-24-2017, 06:42 AM
miniman82's Avatar
Some brighteners are also isolators, so it would work to cure the H/K short. Unless it's directly heated of course, in which case H/K shorts are a given.
Evolution...
Thread Tools
Display Modes
