Old 03-26-2017, 08:11 AM
Old TVs are better!
Wanted: Turntable Motor and Bearings for RCA 7HF-7
I am servicing a retro Orthophonic RCA Mono record player 7HF-7 The motor bearings were frozen solid, so in the process (after much soaking with oil, alcohol, and WD40), I tried to pull and loosen the armature from the bearings. Well the entire bearings came out of the housing so now I need either a replacement motor, or at least an armature with both top and bottom bearings. The Model of the unit is 7HF-7, changer number RVG274745 RP205C2. The number on the motor is A936173-1. If anyone has a motor for this unit, even if the motor needs to be oiled and serviced, let me know. Attached are pictures of the changer and unit. The motor in a 7HF-5 will also fit.
wjb122750@hotmail.com
Old 04-25-2017, 04:59 PM
Old TVs are better!
NOS motor has been found. No longer needed. Moyers came through with a NOS that works perfect.
Thread Tools
Display Modes
