Zenith 9-181 module
I adopted a 13 inch Zenith with the 9-181 module. It had no start. It is the one that does not have the "kick start" sub module. I subbed the 9-181 with a module off the shelf and now I have high voltage, sound, good sweep. But, no video or color. I suspect this module was shelved a long time ago for no video.
The question! Does anyone have a schematic of the 9-181 module? |
Be sure none of the little jumpers are in the wrong place.
Also check the IC pins that none bent when you moved them over. Give the model ## I may have the Sams but try to get a free one first ! 73 Zeno LFOD ! |
I'd check the voltage adjust pot in the power supply for an open spot. I have replaced it with fixed resistors in the past.
I think I have the same set as you, and mine just developed an odd problem. After running for about 20 minutes it shuts off. If you wait a minute, and turn the switch off and back on, it will run a bit and do the same thing. Did these have a shut down circuit if the HV crept up too high? I haven't taken the back off mine yet, but assume everything is crammed in there pretty good.
Yes they do have HVSD circuits. The sets not crammed but
since they were built for board level service its not that easy physically. At its age I would look for cold joints on both the 9-181 & 9-186 boards. Also some had a small start board on the 9-186 bracket. If the IC's have sockets watch that too. Later models have them soldered in. 73 Zeno LFOD ! Quote:
Audiokarma |
BTW I missed that it was a S3 set. It uses the big 9-160
board. 9-181 sets were called "Custom Series". The 9-160's had lots of bad PC cons. Pull it & give it a good goin over. 73 Zeno |
On a 9-160 I found shut down was usually caused by connections on a large diode front right as viewed from the rear of the set. Also, horizontal driver transformer pins were known for poor solder joints. Except for the 10 mfd/315 volt cap, parts failures were rare. Usually a hard failure (horizontal output transistor and a few other parts) was caused by a flyback arc over. As age did get to these modules the dual power supply electrolytic would open.
It lives! After digging out five(!) 9-181 modules all in different stages of having been scavenged over the years, I thought this little guy was hopeless. OOPS! Fleabay! A factory refurb in the box! Well, it was a late refurb that included the IF IC and was as clean as can be! It looks so much better than the picture! It will live atop my T-933 and my TS-4J.
FANTASTIC!
And of course.... I took mine in to be repaired, and do you think it acted up once??? Glad yours is going. Keep your fingers crossed on mine. |
I have seen weak (high ESR) capacitors on the 9-186 board cause intermittents. As mentioned earlier, these sets are a bit of a bear to deal with. My big complaint is the service literature. No voltages marked except for power supply. It is a bit of struggling with the harness' being short. I feel lucky that 9-181 popped up!
I remember the one with kick start being a failure prone set. I also remember when all 9-181 modules had regular start added when sent in for "rebuilding". I just wish we still had analog OTA. This set has a good tuner and I would bet DXing would have been a lot of fun with it! |
Audiokarma |
Several years ago, a church gave me a 25" table set (digital tuner, pull on-volume knob) with a 9-181 module. The problem was a roar from the speaker, very reduced HV, and no raster. All power supply voltages checked low and I was pulling my hair out. I then noticed that one of the B+ lines going to the tuner had a dead short on it. After unplugging that line, the chassis came up with full HV and raster. After looking inside the tuner module, I found a dead shorted large value electrolytic capacitor that was tied between tuner B+ and ground. One new capacitor later and the set worked like new. Coming from a church, it probably did not have a lot of hours on it.
http://www.youtube.com/user/radiotvphononut |
Mom (1938 - 2013) - RIP, I miss you Spunky, (1999 - 2016) - RIP, pretty girl! Rascal, (2007 - 2021) RIP, miss you very much |
At the shop we use a 19 inch sentry all day long. I picked it up a few years ago off the street and was going to part it out but it worked when I plugged it in. It appears to have never been serviced!
Thread Tools | |
Display Modes | |
