Old 05-03-2016, 03:53 PM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
Wanted: 6J9 tube
Need one for my 1076 Television Analyst....I can't find any of these for sale unless I want to order from Russia or China.
Anyone have one to sell?
Old 05-03-2016, 04:22 PM
Looking at the schematic for the 1076 I don't see a 6j9... what is it used for in the instrument?
http://www.schematicsforfree.com/arc...%20Analyst.pdf
Old 05-03-2016, 04:35 PM
Kamakiri's Avatar
Not certain. It's shielded and mounted between two crystals on a separate chassis on the backside of the front, and is the only horizontally mounted tube in the unit.
Old 05-03-2016, 04:44 PM
On the second page of the schematic 2 xtals are shown near v-17, which is a 6AN8... wonder if somebody made a goofy substitution?
Old 05-03-2016, 04:47 PM
N2IXK's Avatar
N2IXK N2IXK is offline
Technohippie
A 6J9 was one of the handful of types with 10 pins, 9 as normal and one in the center. A triple triode. Is that what you actually have?
There is a Russian/Chinese tube with the same designation, but it is NOT the same as a RETMA 6J9. It is roughly equivalent to a 6688 or E180F. It has only 9 pins.
Old 05-03-2016, 06:05 PM
Kamakiri's Avatar
Yep....it has a center pin. I've never seen one before.
Old 05-03-2016, 08:10 PM
N2IXK's Avatar
Technohippie
Thought I had one for you in my oddball tube box, but I looked and it was the OTHER 9+1 pin type, the 6C9 dual tetrode.
There were actually 2 different 10 pin tube bases. This "9+1" type (properly called a "Decar" or B10G base) was a Sylvania design, used (as far as I know) only on the 6C9 and 6J9. The other ("Decal", or B10B) was a European design with 10 pins in a circle, with a gap similar to the common 9 pin base. the 6Y9/EFL200 is an example.
Old 05-03-2016, 08:23 PM
So is there actually a known model/variation of the 1076 that uses a 6J9? anybody here have that variation? or was this an incorrect substitution for the 6AN8 (v-17) made sometime in the past?
Old 05-03-2016, 08:27 PM
Tim's Avatar
Tim Tim is offline
Find-A-Tube lists them new for $3.00
https://docs.google.com/spreadsheets...=2&pli=1#gid=2
Tim
Old 05-03-2016, 08:53 PM
Tim's Avatar
Tim Tim is offline
The unit I have also has the 6J9 in the V-17 location and it is indicated on the tube location diagram.
Tim
Old 05-03-2016, 10:10 PM
Cool! thanks for posting, I have never seen that variant or even a 6J9
Old 05-04-2016, 07:46 AM
Kamakiri's Avatar
It tests weak, but it's making a picture now. One dead tube, 3 shorted tubes, and a 5AN8 put in place of where the 6AN8 should have been.
I'll keep hunting, but for now everything's much better than it was
Thread Tools
Display Modes
