Old 09-03-2015, 04:18 PM
ohohyodafarted's Avatar
Bob Galanter
CRT for GE Portacolor needed
I shipped a working GE Portacolor to John Folsom via Fedex. I had it packed in a heavy duty double wall corrugated box and lined with 3 inches of Styrofoam sheet on all sides and they still broke the crt.
John said that he heard a huge THUMP at the front door as the FedEx driver dropped the box onto the concrete of his front stoop.
Does anyone out there have a pull from a set they scrapped that they would be willing to part with?
ME http://AntiqueTvGuy.com
Old 09-03-2015, 04:58 PM
John Folsom's Avatar
This is John, the recipient of the aforementioned portacolor with the broken CRT. Can anyone tell me what CRT # it uses? Model M213CWD
Thanks!
John Folsom
Old 09-03-2015, 05:37 PM
It should use an 11SP22. I have a near identical set with a beat up cabinet that works well enough to display a picture (I haven't tested the CRT though). Bob, I'd trade you the whole set for one of your CM 25GP22 rebuilds. I don't want to ship it myself...I've never sent a TV by mail, and doubt I'd do a better job than you did Bob.
Old 09-03-2015, 05:42 PM
FWIW, I can provide the GE Greyscale/Purity/Convergence set up from the manual for a PortaColor if anyone needs it. They are a bit different.
Simple scan to PDF....lemme know, tis free.
USN RET (Avionics / Cal)
Old 09-03-2015, 07:32 PM
Bob Galanter
I will have to think on that a bit Tom. I may be inclined to make some sort of a deal if I get any compensation from FedEx for breaking the crt. But I will not hold my breath.
Old 09-03-2015, 09:07 PM
Maybe the management should check into this delivery person's past and see how much damage that person caused, delivering sent items. Maybe it's a habitual thing.
That package is light and was packed properly.
Old 09-03-2015, 09:48 PM
Olorin67 Olorin67 is offline
I have an early poracolor, but since its complete and looks like a low hour set I think i'll hang on to mine. Looks like the white caps in mine are bad, but hopefully it doesnt need much more than that.
Hearing so many horror stories of vintage stuff destroyed in shipping.... Sometimes they get it right. A friend just shipped her grandmothers entire china set from california to wisonsin, and every piece arrived safe... She did pay for them to pack it, in 3 giant boxes. Ive had dammage to a couple record changers and tuners bought of ebay, but on those cases they were really not packed well.
Old 09-03-2015, 11:31 PM
I'd consider including some cash with the Portacolor if that makes any difference.
Old 09-04-2015, 08:31 AM
baursam's Avatar
baursam baursam is offline
Sorry to hear that!!! I recently sent a 7DP4 from Montana to Tennessee with FedEx ground and it arrived in perfect shape. I still find them much better than UPS but sadly am starting to hear more FedEx stories these days!!!
Old 09-04-2015, 11:16 AM
andy's Avatar
It's hard to imagine how the CRT could get broken while the cabinet was intact. Maybe the CRT, or some other part came loose? Certainly, one drop by the driver shouldn't have been able to break it.
Wanted list:
RCA CTC-5
RCA CTC19 or 27
Sony KV-7010U
Old 09-04-2015, 11:51 AM
UPS and FedEx are not the most careful carriers in the world. I have read stories right here on VK of how packages are manhandled by UPS, for example, and I have had at least one bad experience with them. Seven years ago, a Zenith stereo FM radio was sent to me by a VK member. When the radio arrived at my apartment, it worked, but I found loose controls and other things under the chassis. When I emailed the sender regarding this, I was told that the package might well have been tossed around and otherwise manhandled by UPS, despite the fact the radio was packed securely. The volume control was so loose that several connections broke off, and the control itself literally fell apart. The radio has not worked right since, and it is at least partially the fault of UPS for the carrier's rough handling of the package. (I am still looking for a replacement for the ruined volume control, a 2-megohm dual pot; this is almost certainly the only thing wrong with the radio, and someday I'd like to get it singing again.) If this had been a television set, this kind of rough handling would have destroyed the CRT in no time flat.
Cathode ray tubes are extremely fragile. It doesn't take much to ruin them. If the FedEx carrier dropped the TV from any height, the CRT would be destroyed instantly unless the TV has been packed exceedingly well, and much better than the one we are discussing here. I would not trust any of these carriers to ship a television, or any other fragile item for that matter. I can also understand why most eBay sellers will not ship televisions, especially flat screens, any distance--it is just too darn risky. A flat panel TV would be destroyed instantly if it were dropped even a few inches.
Old 09-04-2015, 06:18 PM
rca2000's Avatar
rca2000 rca2000 is offline
Coming to the swap meet? I DO have a porta-color I WOULD Be willing to part out. NOT the one I am talking about selling--this is one I got that was apart when I got it... and I do not know how good the tube is. If you are interested--I will dig it out and test it in a few days. I know EXACTLY where it is and can get to it.
Old 09-04-2015, 06:45 PM
Alas, as I am in Florida, and do not drive, it is too expensive to attend the ETM swapmeet. However, I would be interested in your 11SP22 CRT if it has good emission, and it should not be difficult to ship. Let me know that you think. email jfrosomjr(at)cfl(dot)rr(dot)com
Thanks!
John Folsom
Old 09-04-2015, 06:52 PM
rca2000's Avatar
Thanks!
It MIGHT be asleep...who knows how long it has been sitting idle. BUT..I WILL get it back here.....and see if it can be "woken up" and then show good emission/life and such.
If it is any good....I will let you know.
But are you SURE...it can get to you in one piece ... after all...the OTHER One did NOT.
Old 09-04-2015, 07:42 PM
rca2000, Thanks in advance for your efforts. I have shipped/received many CRTs with no problem. The key is proper packing. But we can cross that bridge when and if the time comes.
Thanks again.
John Folsom
Thread Tools
Display Modes
