Old 02-21-2015, 10:00 AM
Old TVs are better!
Wanted! 6u5 tuning eye tube
I am looking for a good usable 6U5 tuning eye tube for an old Zenith 1948 console radio that I am restoring. If someone has one that is reasonable in price, say $20-25 or so, let me know. Most of the known good ones on e-bay go for over $50.
Old 02-21-2015, 10:12 AM
Paul Knaack Paul Knaack is offline
Heres some things to try if you don't want to spend big money for the 6u5, I've used the 6u5 to 1629 adaptor on one of my old radios and it works great.
http://www.antiqueradios.com/chrs/journal/eyetube.html
"EYE" TUBE HINTS
by Norman R. Leal
Good eye tubes such as 6E5 and 6U5 are getting harder to find. Many of the old ones still have filaments but have lost most of their green glow. You can increase the green by a slight modification of the circuit. These tubes were originally specified for operation on 250 volts. By increasing the voltage on the target, pin 4, on dim eye tubes they may again be useable. I have tested some weak "eye" tubes to 1000 volts and have not had a problem.
To increase the brightness pin 4 should be connected to a higher voltage in the radio. If the radio doesn't have a higher voltage, the addition of a diode, capacitor and resistor should add around 100 volts. Most radios use an 80 for a rectifier. This tube has a high voltage drop and in addition, the rest of the radio circuit loads the voltage down .
Connect a 100 ohm resistor, for protection, to one of the 80 tube plates. The other end of the resistor to the anode of a diode (1000piv). The cathode of the diode should go to the positive end of a 10 mfd 450 volt cap. The negative end of the cap goes to ground in the radio. Now remove the wire which connects pin 4 of the eye to B+ and connect pin 4 to the junction of the diode and 10 mfd cap.
The actual voltage on the eye will be slightly less than 1.4 times the AC plate voltage on the 80. The higher the voltage on the eye tube, the larger the AVC voltage needed to close the eye. The 6E5 tube is more sensitive than the 6U5 or 6G5 and will have more movement when tuning in a station.
If you notice no movement of the eye when tuning in a strong station, either the AVC voltage is missing or a small 1 meg resistor built into the 6E5/6U5 socket is open. This resistor is between pins 2 and 4 and needs to be replaced if it is open.
A voltage doubler can be used on a radio that doesn't have a high enough AC voltage such as AC/DC radios. The doubler can be made up of two diodes and two capacitors. Again, a resistor should be used for protection.
The 1629 tube can be used to replace 6U5, 6E5, 6G5, etc. tuning eyes if you make an adapter and increase the filament voltage to 12 volts. At first it seems like another filament transformer must be added but this is not necessary. The 1629 as well as most tubes will operate on AC or DC for the filament voltage. For AC radios you can make a simple voltage doubler that will convert the 6.3 volt filament of the original tuning eye tube to over 12 volts DC for the 1629. To make the doubler two 470 mfd capacitors and two 1N4001 or similar diodes are required. See the diagram below:
Copyright 1995 California Historical Radio Society, all rights reserved.
No part of this publication may be reproduced in any form, or by any means, without prior written permission from CHRS, except that you may make "fair use" of quotations of text fully attributed by you to the source (CHRS Journal) and author.
CHRS
PO Box 31659
San Francisco, CA 94131
Thread Tools
Display Modes
