Old 08-12-2014, 09:41 PM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
Television Part Cross-Referencing, post here
I managed to pick up some pretty complete Thordarson Meissner, Miller, Stancor, and Workman parts catalogs recently, so we might as well put them to use
If you have a set that needs a part and you need a part number, post it here and I'll do my best to look it up. Model numbers, chassis numbers, and OEM part numbers help out quite a bit in finding the correct applications.
If you have a part but don't know what it fits, I'll do my best to ID it.
Most of my catalog listings end around 1963 or so, but I'll do my best....
Old 08-12-2014, 10:04 PM
Great idea! I have some references that I'd like to put to use as well; some run up into the late 70s. It's a good feeling to be useful once in a while!
Old 08-13-2014, 04:15 AM
A reminder that Triad has their last TV cross reference online:
http://www.triadtransformers.com/tv81.html
While not as extensive as Thordarson, Triad did cover the bases with the most popular brands. They were the first with the silicone-based flyback encapsulation. I never had a Triad tranny or fly go bad. Guess that's why they are still in business.
Cheers,
USN RET (Avionics / Cal)
Old 12-29-2014, 07:02 PM
Doug66 Doug66 is offline
Silvertone Coil
Hi, I need a cross reference for a Silvertone coil 10-120-1. It goes in a Silvertone TV chassis 528.50124. Sams 389-3 does not list any cross references.
Thanks
Doug
Old 12-29-2014, 09:54 PM
Tim's Avatar
Tim Tim is offline
Crosses to Merit TV-236 and Thordarson 17-1072 (remove capacitor between primary and secondary).
Tim
Old 12-30-2014, 10:28 AM
Silvertone Coil
Tim,
That helps a great deal. Thanks so much for the info.
Doug
Old 05-30-2015, 05:07 PM
Video IF Coil
Hey,
I need a cross reference for a Silvertone Video IF Coil. 10-77-2.
TV chassis is 528.50123. Sams 389-3.
Thanks
Doug
Old 05-30-2015, 08:03 PM
Kamakiri's Avatar
Originally Posted by Doug66 View Post
Hey,
Thanks
Doug
Tricky one. My Workman catalog goes from 10-76-2 to 10-81-2 and my Miller lists nothing at all. Thordarson lists that Silvertone number but no replacement part number is indicated.
My catalogs *might* be too old on this one.....hopefully someone else can chime in
Old 05-31-2015, 10:35 AM
Kevin Kuehn's Avatar
Kevin Kuehn Kevin Kuehn is online now
Workin' Late Again
Thordarson replacement should be 17-5037
Old 07-24-2015, 08:39 AM
Channel Master 1973 CRT Sub guides. Enjoy.
Old 08-27-2015, 02:43 PM
1966 EIA Production Source Code list:
https://drive.google.com/file/d/0B9H...ew?usp=sharing
Old 02-12-2016, 05:51 PM
Cosley Horiz Lin Coil
Can you look up cross reference for a Crosley Horiz Lin Coil Part # AW-144551?
TV Model is 9-403. Sams # 79-4
Thanks in advance
Doug
Old 02-12-2016, 07:39 PM
Kamakiri's Avatar
Shows that it directly crosses to a Stancor WC-5. It *may* also cross to a Miller 6318, but not 100% on that one. Workman T108 or T110 should do also.
Old 02-12-2016, 11:41 PM
Tim's Avatar
Tim Tim is offline
Merit MWC-12
Tim
Old 10-23-2016, 05:02 PM
Big Dave's Avatar
Big Dave Big Dave is offline
Dead from the neck up
Zenith flyback S-46564. Triad D-197, Merit HVO 196. Need thordarson if you can.
The world's worst TV restoration site on the entire intranoot and damn proud of it.
http://evilfurnaceman.tripod.com/tvsite
Thread Tools
Display Modes
