Old 05-29-2014, 10:58 PM
Biker
WTB: Zenith Convergence yoke (25LC20 chassis...)
Ok, I know I'm like everyone else, I'm looking for one of these because the stupid plastic broke apart
Anyone got one?
Or, if you've got a busted plastic one without the coils in it, that might work too - I've got a friend with a 3D printer and I might be able to get him to duplicate the thing.
ISTR there was an aftermarket replacement that had the coils encased in red, green, blue cases and worked very well - I'll take one of those. I'm not looking for a 100% origional look here, just a decent picture on screen
Thanks!
Old 05-30-2014, 07:38 AM
tvdude1 tvdude1 is offline
zenith
I have 3 zenith tubes with the coils. They are 21 inch round screens. Junked the chassis. Can you get me a picture?
Old 05-30-2014, 10:55 AM
Biker
I'll get a picture tonight.
Old 05-30-2014, 10:42 PM
Biker
Ok, here it is. I guess I just need the plastic cloverleaf part, but I'll take the whole thing. Yeah, the wiring really IS that nice and clean on that set. It's in pretty nice condition...
Old 05-31-2014, 03:15 PM
Good condition ? Hell no, new condition ! Almost unbelievable
for age. Not an old dried up set. I dont know how Zenith got
away with using the high quality hookup wire and stay in
business. Nobody else I remember came close. Most wire near
any heat would dry up & crumble............
BTW Have I lost my mind or is something backwards on the set
Old 05-31-2014, 07:16 PM
Motorola was another firm that used a little better quality wire in their products. It was probably Belden.
IIRC, they used silicone hi-temp insulation on the horizontal output plate cap, as well. Zenith did too.
RCA, didn't have to worry about wire quality on their flybacks. They never lasted that long.
The CTC15 and clones would burn the wiring and the tie strips around the large voltage dropping resistors, under the hi-voltage area.
The replacement Zenith cloverleafs were made from a better green plastic.
IIRC, they were rather cheap, like a buck or less.
Old 06-03-2014, 08:51 AM
Biker
Ok...anyone?
Old 06-03-2014, 08:43 PM
If that is a picture of your damaged one in it's current condition then I think a full on replacement might be overkill. A crack or a decent sized piece busted off can often be fixed with super glue (trust me, I've done it before).
Old 06-03-2014, 10:18 PM
They dont like that, maybe a little newer.
Old 06-04-2014, 10:03 AM
Super glue is fine for most plastics, but some it's not compatible with, like eyeglass frames. Also, items that are under tension or torque.
The only recommendation, I would have, is to find another type convergence cloverleaf, from a newer Zenith or another make roundie.
Thread Tools
Display Modes
