Old 05-27-2014, 10:37 AM
farmradio farmradio is offline
RCA Delay Line Part #116505 needed.
Hello, I am in search of the following two items for an RCA CTC24A.
RCA Part #116505 Delay Line.
RCA Part #116543, or #121446 4.5Mhz. trap. (also Miller 7616).
Thank You.
P.S. Still on the hunt for a good 21FJP22.
Old 05-27-2014, 01:39 PM
Tim's Avatar
Tim Tim is offline
Talon electronics lists both the delay line and the 121446 trap as in stock.
http://www.talonix.com/shop/rcaparts.htm
Tim
Old 05-27-2014, 07:00 PM
Re: Talon
Hi, & Thank you. Those guys have never replied to any of my prior inquiries. No phone# either. Will keep trying, but they've never gotten back to me.
Old 05-27-2014, 09:50 PM
jstout66 jstout66 is offline
Did you try Moyer Electronics?
Old 05-28-2014, 08:51 AM
Re:
Yes I did, thank you. No stock. Talon did reply to say they sold the last one in April. They have one for a later tube type chassis. Might take a chance on that.
Old 05-28-2014, 09:03 AM
Re: Delay Line Needed. Pic.
Shot of the original w/ 1472703-1 on it. Believe the other is a date code.
File Type: jpg 2014-05-28 09_57_16-ctc24 update - YouTube.jpg (8.0 KB, 21 views)
Old 05-28-2014, 12:58 PM
It's just a coil of wire, figure out where it broke and fix it......
Never doubled, just one layer deep, easy fix....
Old 05-28-2014, 06:53 PM
Bill R Bill R is offline
I don't recall the delay line part number being that critical. One from about any similar set should work. I don't think there was much actual difference in the RCA delay lines. I used to take them from junk chassis.
Old 05-29-2014, 06:43 AM
You can try any delay line. If its wrong you get a ghost or
smeared pix.
BTW the number on the old one is a drawing number. You
had to cross that to the 6 digit part number. Dont know why
they did it but you never saw the 6 digit numbers, just
drawing numbers.
Old 05-29-2014, 03:01 PM
StellarTV's Avatar
StellarTV StellarTV is offline
I have a delay line I can send over from a CTC16. I've been following the resto of your chassis on Shango's youtube channel and I've emailed him also. If you still need it I'll send it over 1st class.
Magnus Rubsam
Stellar Vintage Electronics of California
CRTs, Restorations, Chassis, and Color Conversions
Old 06-10-2014, 10:04 AM
Re: Delay Line.
Hi Stellartv, Sent a message along also. Should be close enough I would assume.
Thank you.
Old 06-10-2014, 10:06 AM
Hi, I believe the corrosive material may have shorted it's winding to the core which is ground, or something like that.
Thread Tools
Display Modes
