Old 05-18-2014, 05:41 PM
wiseguy wiseguy is offline
N.O.S knobs and Yokes
I have a ton of misc NOS RCA KNOBS/Parts and in this list is a bunch of knobs and yokes (with plugs) to Donate to someone who actually needs then and (not to just Hoard), just pay for Postage, hopefully you can zoom in and see part numbers, my Camera takes too large of images so I had to resize, some part numbers are Below and there are several knobs in each box, if unsure then ask me and I will look again
there are no boxes for the Yokes so I have no idea
I do not have a cross Reference for these part numbers and some boxes the ink has faded
100638-b
100944-b
100620-b
101150-b
100945-b
101153-a
or if you are in the area of cottage grove Wi I can hold for you
I thought that some of these knobs were for RCA CTC Round Series sets, but Can't remember.
Old 05-18-2014, 06:06 PM
One in the back of your first photo looks similar to a knob that I'm seeking (see below). Channel selector for RCA CTC-4, part number 79508 according to Sams.
Phil's Old Radios
Old 05-18-2014, 06:13 PM
hmm
it is green inside like yours, I will pull it out and send a picture via email.
Old 05-18-2014, 09:22 PM
Penthode's Avatar
Penthode Penthode is offline
I am looking for a clear channel selector knob for my RCA CTC11c. The knob is clear transparent plastic. I can post a picture.
Are all the knobs depited in you photographs?
Thanks,
Terry
Old 05-19-2014, 05:53 AM
I can always send the larger images and you can look, but I still have other boxes that I have not sorted thru, i have had these for years and their new but dusty, I think I found Phils Needed CTC-4 knob, it looks like a lot of the channel selectors are for CTC-5 and CTC-7, there or some of those odd side push in knobs for the ctc-5 and ctc-7 (I think)
Old 05-19-2014, 08:48 AM
hi_volt's Avatar
hi_volt hi_volt is offline
Vintage TV and Radio Nut
I could sure use a channel selector knob for my CTC-7 Pensbury. Mine is missing, so I can't post pix, but I understand it has a relatively long shaft. Thanks.
http://www.videokarma.org/showthread.php?t=261057
Bruce
Old 05-19-2014, 10:28 AM
I will look and see if any of them have long shafts, I don't have a CTC-7 anymore so I can't remember, but will check
and here is all I can find with long shafts, someplace I seen someone else use one of these
Old 05-20-2014, 08:54 AM
hi_volt's Avatar
Anyone got a picture of a CTC-7 channel selector knob that they could post here? Mine's missing, so I don't know exactly what it looks like. Thanks!
Old 05-20-2014, 03:27 PM
are these knobs for late 50's CTC Color sets, that go on the side for bright/ contrast? 2 different colors
Old 05-20-2014, 06:35 PM
I went to photograph the channel selector knob on my CTC-7, and whaddya know -- it does not look original. The color doesn't match the other knobs and the fit is loose. Amazing what you forget when you haven't used a set in a while.
I guess I'm in the market for a CTC-7 VHF channel selector, too. The part number given in Sams is 104986. There are seven VHF channel selectors listed for the various cabinets. Most of them have part numbers 1049xx. A couple of others have 106xxx numbers. I'm guessing any of them might work physically, but the color might be off.
Old 05-22-2014, 06:18 AM
so Far it looks like all the ones I have are for the ctc-5 series, the ones that look like for ctc-7 do not have long shafts.
however there are 2 channel selectors that may work if you have none shown a post above.
but I did find out the smaller knobs shown above are for on/off volume and Brighness for the CTC-7, I have the CTC-4 knob that phil needs, don't want to run to post office yet and mail anything till I have more to mail
so later once I am home from work I will take close up pics of the channel selectors again, (its 5:15 am and yes I am at work yet) lol
Old 05-22-2014, 03:42 PM
well here ya go, hope this helps on Choices and What fits for Channel selection
Old 05-22-2014, 10:13 PM
Tim's Avatar
Tim Tim is offline
Phil:
I believe the knob for both your and Bruce's set is the scalloped style with a long shaft and the brass circle insert. That type, without channel numbers, was used on the better model sets that had the channel number displayed in a front window next to the CRT.
The economy model sets that did not have the front window used the knob with the "engraved" channel numbers.
Tim
Old 05-22-2014, 10:55 PM
You wouldn't happen to have another CTC-4 channel selector knob or any other knobs for that set? I've been looking for a channel knob for a good 3+ years now...My channel knob is missing and the others are beat up to the point that they are almost as good as missing.
Old 05-23-2014, 06:35 AM
I will look and see.
anyone interested in those yokes? I wonder if I can place them in recycling bin
Thread Tools
Display Modes
