Old 06-20-2013, 07:08 AM
47'Plymouth 47'Plymouth is offline
Smile I want CRT pin crimper!
Need a CRT pin crimping tool do ya'll have one you can spare
Old 06-20-2013, 07:21 AM
WISCOJIM WISCOJIM is offline
47'Plymouth gets first dibs if one's available, but if a second one turns up, I'm interested in finding one also.
Old 06-20-2013, 03:38 PM
Thanks WiscoJim!!
Old 06-20-2013, 04:06 PM
You probably don't want one........
If you are having trouble soldering the wire to the pin, its because the wire and/or the pin are badly oxidized. Crimping it will ruin chances of removing the socket, and it will most likely fail again as the oxidation over 50 years remains mostly on the wire. Not to mention if some of the glue got down in there too. You are much better off de-soldering it, using a small drill bit by hand to scrape the pin, and wire, load it with solder flux, and try soldering it until you succeed in making a good solder joint.
If you really think the crimper is the solution, just ask people who have repaired wires on their car with the little crimp connectors, they all oxidize and have to be redone.
Old 06-21-2013, 01:08 PM
It's for my museum Tv and radio collection!!
Old 06-21-2013, 06:19 PM
markdi markdi is offline
markdi
What does a crt pin crimper look like ?
Old 06-21-2013, 08:08 PM
Restoring Admiral T2301
I found one on eBay recently and started a thread about it: http://www.videokarma.org/showthread.php?t=258473
I didn't expect it to spark so much interest. I bet there are lots floating around in toolboxes but no one knows what they are
Thread Tools
Display Modes
