Old 06-10-2013, 04:32 PM
vts1134's Avatar
vts1134 vts1134 is offline
Looking For Time
Mica Capacitors
Does any one know where I can find NOS mica capacitors like the one pictured? This is the first time I've run across a bad mica in my restorations and I don't know where to find a replacement, I can only find new "silver dipped" style. Every other component in the set is undecernable from original so I'd had to have one out of place part keeping me up at night .
Old 06-10-2013, 05:26 PM
ill look , i have box's of nos mica caps, i got from old guy 2yrs ago never used post the value or colors and ill see if i have one and ill mail it to you. not sure of one of the colors in picture
Old 06-10-2013, 05:38 PM
vts1134's Avatar
Looking For Time
The capacitor is 4700mmf.
Thanks for looking.
Old 06-11-2013, 12:21 PM
vts1134's Avatar
Looking For Time
Does any one else know a consistent source for these?
Old 06-11-2013, 12:27 PM
i have been threw 2 boxs so far i seem to have everything but 4700 mmf , can you take another picture of it at a different angle so i clearly read whats on the face ,and your sure about the value. thanks
Old 06-11-2013, 12:29 PM
dtvmcdonald's Avatar
Many of those old mica caps are so large that one should be able to use
a Dremel (sp?) tool to cut them in half parallel to the flat side,
grind out the innards, and install a modern usually much smaller cap
inside. If it won't fit at least you could make a sandwich and fill
in the gap with putty and paint it the right color.
Old 06-11-2013, 01:53 PM
bob91343 bob91343 is offline
I have a couple .004 and .006 each, gold color, made by Solar. Pics available. If you can use any let me know and maybe I can shoot it to you for postage and a bit more.
Old 06-12-2013, 10:29 AM
well i tryed , i seem to have alot of the same numbers ,now i see why i have 3 box's of them he dint use them either. i have some here and there if i run across before you find one ill let you know. i have 4500 mmf in mica
Old 06-12-2013, 11:15 AM
vts1134's Avatar
Looking For Time
Close enough!
Thread Tools
Display Modes
