Old 11-18-2012, 01:14 AM
WTB: Back cover for Admiral 24C15 12-inch console
I need a back cover for this:
It's a 12-inch TV with the split chassis. I have never seen a back for one of these, so I don't know whether it's pressboard or metal. There are screw holes in the upper back portion, so something obviously used to be there.
You can email me direct via http://antiqueradio.org/contact.htm .
Regards,
Phil's Old Radios
Old 11-18-2012, 01:54 AM
Kevin Kuehn's Avatar
Workin' Late Again
Here's one that came off an Admiral 12" combo set. Measures 15 3/4" across by 13 1/8" top to bottom at the outside edges. Close?
Old 11-18-2012, 08:00 AM
oldtvsandtoy oldtvsandtoy is offline
Banned
Did they make a 10" and 12" set with the same cabinet? See my post
http://videokarma.org/showthread.php?t=256437
Old 11-18-2012, 01:02 PM
charokeeroad's Avatar
charokeeroad charokeeroad is offline
John Q
I think this knob set might work on your set, in case you need them.
http://www.ebay.com/itm/190753840749...84.m1438.l2649
Old 11-18-2012, 01:53 PM
Restoring Admiral 26X56
The 12" cabinet is a little different to accommodate the larger CRT.
This is what the correct back for Phil's set looks like.
Old 11-18-2012, 04:57 PM
Thanks for the responses. I found a photo that I took before I started refinishing, and added some dimensions for the rear cover:
The upper opening in the cabinet is 16 1/2 inches high. On the sides are two pairs of holes whose centers are 16 5/8 inches from side to side. Those holes are 11 1/2 inches from the upper to the lower. These dimensions are from the screw hole centers.
I don't care whether the holes in the cover exactly match those in my cabinet, as long as the cover is wide enough and it isn't so tall that it hits the shelf for the upper opening, which sticks out beyond the sides in the rear.
Regards,
Old 11-18-2012, 10:03 PM
Banned
Are you sure this is a 12" set and not the 10" set?
Regards,
Phil's Old Radios
Old 11-19-2012, 12:06 AM
The CRT is a 12LP4.
Thread Tools
Display Modes
