Old 12-29-2010, 11:23 PM
newsomebuy's Avatar
newsomebuy newsomebuy is offline
LasVegas Vintage TV Lover
CRT Connector Needed GE Model 817 1949
I need a connector for my 1949 ge model 817 crt tube. Or a lead to find one!!!
Thanks
Old 12-31-2010, 10:10 AM
Thanks
What's the CRT #? This would lead to a basing, which then would lead to a CRT socket. Or are you talking about the High Voltage anode lead?
Cheers,
USN RET (Avionics / Cal)
Old 12-31-2010, 03:00 PM
Restoring Admiral 26X56
The GE 817 uses a 12KP4.
Old 12-31-2010, 03:02 PM
newsomebuy's Avatar
Model 817
I beleive it is a 12KP4 CRT for a model 817 GE, Sorry had another thread going and thought I put it on both LOL
Old 12-31-2010, 09:20 PM
jbivy jbivy is offline
complete novice
ive a 50s portable GE chassis with the crt connector still on it, i dunno if its the right one though. can you attach a pic of the correct one? Id let you have it if it is.
"Good morning whiskey, good morning night. The end of the world is in my sight." Hank 3
Old 12-31-2010, 10:11 PM
newsomebuy's Avatar
Yes I have a pic on my profile and or can get you more if you need them from different angles. Let me know and thank you...
Old 01-01-2011, 09:06 PM
complete novice
sorry, its different from the one in the pic.
Old 01-01-2011, 09:14 PM
If your talking about the base connector most B&W tubes from the late 40's through the late 50's were pretty much the same.
Same could be said for the high voltage connector too really.
Old 01-08-2011, 02:31 AM
newsomebuy's Avatar
Eric, Do you have one or know where I can get it?
Old 01-08-2011, 02:42 AM
Here's a whole bunch on ebay. I think you need the duodecal (12 pin) one.
http://shop.ebay.com/i.html?_trkparm...4.l1513&_pgn=1
Another place to get one is from a CRT brightener like this. Just cutoff the brightener part and use the socket. You wouldn't need that blue wire, just the other 5.
http://cgi.ebay.com/TELEMATIC-CRT-BR...item20b389a528
Old 01-08-2011, 03:51 AM
newsomebuy's Avatar
Hey guy your the best and thanks for finding those. I think the second link is the best shot and looks like maybe it well fit.
But I have what you might think is a stupid question. Exactly what does this thing do. It appears to me that it just holds the wirs to the tube but does nothing else. If this is true then why can't the wires as I have them in the picture just be connected onto the post [the 5 posts on the left]?
What well happen if they were, I'm think that thats how someone had it.
Smiles
Ron
Old 01-08-2011, 04:10 AM
You are correct - that's all it does. However, a proper socket will hold them more securely and safely. If one of those leads was to slip off or short to one of it's neighbors, bad things could happen.
Old 01-08-2011, 04:12 AM
Ron, that thing is a brightener, used to get a few more months of use out of a weak CRT.
I'm not totally clear on exactly what you need, is the tube missing it's base cap or do you need the socket that's wired to the chassis?
If you just need the socket you could cut the one off that brightener and wire it into your set then plug it onto the tube.
Old 01-08-2011, 04:45 AM
I coulda sworn there were some pictures in this thread before. Anyway, here's one Ron sent me earlier.
I don't know if this is how GE originally wired it or someone has done some work on it.
I recommended he post here to get some help.
Old 01-08-2011, 04:52 AM
newsomebuy's Avatar
I think and bandersen knows the name of it but it's just the connector to connect the 5 wires to the end of the CRT tube.
Banderson found this one and it looks like it might fit... but only need the five post as thats all the wires I have to connect to it
http://cgi.ebay.com/NEW-12-PIN-DUODE...item35ae5694da
In my pictures I have a picture of the wires where I just stuck them on the end of the tube, but I know there was suppose to be a connector there and Branerson found a picture of the same type chassis and it showed a half moon thing black in color that connected the wires.
Also a big question? which order do these wires connect. I swear I feel like I am walking through a mine feild and hoping I don't hit the trip wire
I have a copy of the orginal plans to the set but they don't show the wire colors. their are 1-x-orange, 2-x-black, 2-x-yellow total 5 wires...
Oh and just kinda wondering can a CRT tube just blow up messin with the wires?
Thread Tools
Display Modes
