Old 09-03-2010, 06:19 PM
Restoring Admiral 26X56
Smile Cleaning House - free stuff
Here's some stuff for free if you can come pick it up.
First up 2 scopes.
A Kikuksi 555G 7 MHZ scope. Here's the manual
A very similar Data Instruments 555/N scope. These are both hybrids using socketed transistors for everything except for two output tubes that drive the deflections plates. The construction reminds me of Tektronics.
Next up, an empty Philco 38-4 cabinet. It has a few veneer issues, but is sound otherwise. Maybe you could mount one the scopes inside
I'll be digging out some more stuff soon.
PM me for details if you're interested.
Bob
Old 09-03-2010, 10:14 PM
Here are some Zenith Space Command remotes. These I'm willing to ship if you cover the costs.
Old 09-04-2010, 12:13 PM
miniman82's Avatar
First Light: 1952-2011
Would you be willing to hang on to the Tek for me, till I can come swoop it up?
Evolution...
Old 09-04-2010, 07:39 PM
Sure, I can hang on to it for you.
Old 09-04-2010, 11:45 PM
I really like that series of Philco radios. I just had this 38-7, pictured, given to me. It's a little more than I want to tackle. The chassis will need plenty of work but could be restored...if somebody wanted the chassis out of it to fit into this 38-4 cabinet, let me know. I can't say 100% if everything will line up. If anyone local wants the whole thing, it's free.
Or, I do like the idea, touched on here, of mounting a CRT in there! Imagine what you could do if you had a VT71 with a trashed cabinet but good 7JP4.
Old 09-10-2010, 06:00 PM
The blue Tektronix scope has gone to miniman82
More stuff to come...
Old 09-10-2010, 08:38 PM
miniman82's Avatar
Thanks Banderson, I'll have to see about getting that knob replaced. It will be used on a regular basis, believe me!
Evolution...
Old 09-11-2010, 11:21 PM
mbates14 mbates14 is offline
Sounds to me you need to build a huge storage shed out in your backyard. hehe.
Old 10-04-2010, 12:28 AM
miniman82's Avatar
Bob-
Thought I'd let you know, I got the other channel on the scope working. Turns out the transistor array in channel 1 had an open transistor on it, replaced it and it works like it's supposed to. Now I just need to find another knob and long fiberglass shaft for the 'VAR' in the center.
Evolution...
Old 10-04-2010, 12:59 PM
Reece's Avatar
Reece Reece is offline
miniman82, try a hobby shop that caters to model railroaders and look through the plastic shapes. They'll have some long plastic rods and tubes that you might be able to use. In a pinch you could use a wooden dowel.
Reece
Old 10-04-2010, 04:13 PM
Bob-
I'm impressed! Did you have a schematic to work off of ? Was it a specialty transistor ?
Old 10-04-2010, 09:26 PM
miniman82's Avatar
Yes, I found a schematic online. I tried replacing the channel switching diodes first because it would deflect full positive when ch 1 was selected, but it didn't end up being those or the trasistors farther back in the circuit. My brother was able to scrounge up the chip lucky for me, installed it and it worked 5.0.
Evolution...
Thread Tools
Display Modes
