Old 07-13-2010, 03:43 PM
holmesuser01's Avatar
WTB: B/W Magnavox VHF Tuner--circa 1961
The part number on the tuner is 340007.1
The tuner I have is working, but the fine tune slugs are damaged and loose. I've done a temporary repair using fine pieces of paper to shim the slug sleeve enough to keep the slug from falling out.
I can also use a parts tuner. This tuner runs with 6V filament tubes.
Thanks for looking!
Bruce McGee
Asheville, NC
Old 07-31-2010, 11:21 AM
BUMP--
Not kidding about the tuner. A parts tuner would be great. The entire tuner coil assembly comes out as a single piece. The one I have is working, but I know it won't last this way.
I remember seeing this tuner in TONS of early '60's Maggies. Where are they now?
Old 07-31-2010, 12:39 PM
Hello Bruce. I scrapped a Magnavox combo simular to the one you a working on. It's a newer model , but magnavox didn't change their B&W models that much. It's a standard coil turret tuner. You can have the whole cluster as it has UHF too. Please reply. Thanks, Dave.
Old 07-31-2010, 06:32 PM
bruce if you get that tuner from the other dave, and have an extra tuner cover from your bad one, let me know. I need a tuner cover for my philco roundie tuner
http://www.videokarma.org/showpost.p...6&postcount=14
Old 08-01-2010, 10:10 AM
DaveWM,
The tuner I have has the cover. I will be in touch on this.
Old 08-01-2010, 10:58 PM
rogher that thx!
Old 08-05-2010, 05:42 PM
Hi Dave! I got the tuner, and your address. I will be sending you $$ as soon as tomorrow.
Not sure how this will work on my set, yet, but, stranger things have happened!!
Bruce
Old 08-05-2010, 08:28 PM
oopp wrong dave
Old 08-05-2010, 10:04 PM
It's OK. Easy mistake.
Old 08-06-2010, 09:03 AM
Hey Bruce. There should no reason that tuner wouldn't work, barring shaft length or other mechanical issues. The tube compliment is different but parallel 6.3 volts. Earlier tuners used 6CG8/6GK5 while this one uses 6HB7/6HQ5 . 41MHZ IF. B+ and AGC the same. Best of luck. Dave
Thread Tools
Display Modes
