Old 05-09-2010, 04:15 PM
pearsonk pearsonk is offline
10Meg resistors needed
I'm restoring a couple of projection sets and need eight(8), 10Meg, 2W resistors. Can anyone help. I can buy or trade something.
thanks..........
Old 05-09-2010, 08:33 PM
Are they separate for a reason, or could you use one 80 meg, 2 watt resistor, or some other configuration to achieve the 80 megs?
The focus resistors used in some RCA sets were 1 watt, 47 Megohms, and some Sears sets used 80 Megohm, 1 watt resistors. These might be more "obtainable" than the 2 watt variety. Victoreen and Caddock make high-wattage high resistance resistors.
Just trying to help,
USN RET (Avionics / Cal)
Old 05-09-2010, 08:35 PM
Just noticed the "couple of sets" - 40 meg resistors are easily obtainable in high wattage, if that's what you ultimately need.
Cheers,
Old 05-09-2010, 10:08 PM
They are used as a voltage divider for a '49 RCA projection set x2. Physical layout
means these values will work best. Thanks for input, a PM just received has some
NOS ones he is sending.
thanks all.....
Thread Tools
Display Modes
