Old 04-17-2010, 11:59 PM
Winky Dink's Avatar
Winky Dink Winky Dink is offline
Need a focus coil for Motorola 12T2 (TS-53 Chassis)
I've come to the end of my first restoration attempt unless I can replace a dead focus coil. There has to be one out there, somewhere.
So everybody please stop everything, quit your jobs, drop out of school, and help me find one!
My beloved Motorola is our family's first TV, a 1950 model 12T2. Other models with the same (TS-53) chassis are 12T1, 12T3, 12K1, 12KS, and 12K3.
The Motorola part number is 24B792581.
Thanks.
Old 04-18-2010, 12:18 AM
Restoring Admiral T2301
I have a spare TS-60 chassis. I wonder if that focus coil would work ? Here's a picture.
Old 04-19-2010, 10:10 PM
The Thordarson catalog says that they never made a replacement, and that the TS-53 uses a different coil than the TS-60. I don't want to sound negative, though! I'm sure somebody has it out there-gotta be a parts chassis sitting around...
Old 04-19-2010, 11:05 PM
I once took apart an RCA focus coil to paint it, it was very simple, just a big coil of wire.
If yours can be taken apart it could probably be rewound quite easily with a drill and a spool of the proper sized wire.
You may even get lucky and find a break in the windings close to the end.
Old 04-20-2010, 02:20 AM
Winky Dink's Avatar
Thanks for the helpful information. I've already taken apart the coil's case, and I've fabricated a crude rig to unwind, possibly repair, possibly rewind. In any case, my first restoration is a can't-lose situation. If I end up with nonworking, nostalgic piece of furniture--well, that's what I intended when I first brought it home.
Old 04-20-2010, 05:51 PM
I update my pic above. Bryan was right - I have a 24B792169.
Old 04-20-2010, 11:56 PM
Rewinding is a good idea and I'd be curious to hear whether it works. When rewinding, I imagine you'd want to take it slowly and try not to cross strands more than necessary, which could result in a coil significantly larger than the original. Watching how the wire unreels should tell you how to lay it back in.
Think of it as a fun science project. If it works -- hey, free coil! If not, it was no good, anyway.
Phil
Old 04-22-2010, 03:52 AM
Winky Dink's Avatar
That was my thinking, too--I've got nothing to lose. So I made a crude wind/unwind apparatus and went to work. I've unwound about 15% of the coil and I've found three breaks so far, and they're all on the same outer edge of the coil. There might be some green copper oxidation associated with the breaks. After repairing the second break there was continuity through the coil with appropriate resistance, but when I started to rewind, another broken end popped up. I'll see about joining the third break tomorrow.
Thread Tools
Display Modes
