Old 04-02-2012, 06:23 PM
chipper chipper is offline
Capacitor Checker
Looking for a Newer model cap checker, at a reasonable price and suggestion?
Old 04-06-2012, 09:14 PM
How new ? Do you need to check ESR on electrolytics or just for leaky old paper caps ?
I've heard the Sprague Tel-Ohmike's are pretty nice, but the newer models can be pricey.
Personally, I use a vintage Solar CB-1-60 and Simpson 383A Capacohmeter. Both work well for testing micas and paper caps but are somewhat limited for electrolytics.
Old 04-06-2012, 09:21 PM
bob91343 bob91343 is offline
Oh my goodness, that Solar unit is the same as one I used to have! Such memories it evokes! With a 6E5 electron ray indicator and a 1-v rectifier, I got years of use out of it.
Right now I have two instruments, both General Radio bridges, that measure capacitance at low frequencies. One also measures ESR. If I need a high frequency measurement I cobble up a circuit with an RF generator and an oscilloscope.
I had a Hickok VTVM with a capacitance function but that didn't actually measure capacitance; it measured voltage drop at 60 Hz, which is only valid for low loss capacitors.
Old 04-07-2012, 06:44 PM
Yes; That test eqoupment looks great, I would like to find something that could test just about any type found in vintage tv and radio set's .
Old 04-12-2012, 03:13 PM
DavGoodlin's Avatar
Motorola Minion
That Solar unit seems to be similar to the EICO 950 I built and still use. It works fine for me.
