Old 05-13-2016, 12:30 PM
Adam's Avatar
Adam Adam is offline
another 1962 RCA 19" B&W
I recapped this set and had to take apart and repair the on/off switch. It was one of those push/pull types combined with the volume control.
I just tested this out and it works good. After I recap, I usually still have to change at least 1 tube, or a bad resistor messing up the horiz or vert sweep, but not here. I still have to clean the tuner, polish up the cabinet, and make some adjustments, but then I'll be done with this one.
The quality goes in, before the cat goes on!!
Old 05-13-2016, 08:03 PM
Adam's Avatar
I took the CRT out to clean the inside of the glass and the cabinet, then put the whole set back together, turned it around, and saw that I didn't quite get all the dirt off the back of the glass. Now I have to take it all apart again...
Old 05-13-2016, 08:13 PM
TUD1's Avatar
TUD1 TUD1 is offline
TheUniversalDave1
For glass cleaning, I highly recommend Invisible Glass. It's way better than Windex.
"If you wish to make an apple pie from scratch, you must first invent the universe." -Carl Sagan
Old 05-14-2016, 02:22 AM
Adam's Avatar
I don't even have any windex, been using just soapy water!
After letting it run for a while, I needed to replace a weak AGC tube, clean some controls, and do a little resoldering.
Here's a pic of it all together. It's missing a blue plastic washer that would go between the volume control and the top of the cabinet.
Up next is a '59 GE 17" B&W...
Old 05-14-2016, 10:23 AM
It looks like the more deluxe model
Is the AGC tube a 4AV6?
Does the on-off switch have the bakelite back on it? I have replacement switches for them, probably NLA.
Old 05-14-2016, 08:54 PM
Adam's Avatar
The 4AV6 was ok, it was the 6GY6 that was weak. I think the bottom of the switch was plastic. It's not as deluxe as my other KCS137 with the remote though. I was surprised this one didn't have a lighted dial. The mechanism with the clear plastic cylinder which rotates around and displays the channel number is the same in both sets, but the remote one has a light inside it and this one doesn't.
Old 05-15-2016, 09:45 AM
Mallory used to sell nice PP on/off switch replacements, the
KR8 & KR9. All metal. Get some if you spot them.
Old 05-15-2016, 10:09 AM
I thought mine were Centralab, the KR8 number is familiar.
Old 12-23-2016, 06:19 PM
Adam's Avatar
I just recapped another one of these, a 1963 KCS-138. I still have to take out the CRT and clean all the dust in front, otherwise it's fixed. Now I have 3 of these 19" RCAs in this cabinet: A 61 KCS 137 with a mechanical remote, the 62 KCS 137 earlier in this thread, and this 63 which has the original stand.
Old 12-23-2016, 07:34 PM
Aw man, we sold a boatload of those. Some in that same color too. Trippy.
Old 12-24-2016, 01:16 AM
Adam's Avatar
Here's all 3 together, from left to right: the 61 remote set, the 62, then the 63 on the stand. I've got a black 17" 59 RCA on the other side of the room too. Now I need to find a 1960 to complete the set.
