Behind the scenes UK experimental colour transmission 1957
G'day all.
Just found this amazing footage on YouTube: http://www.youtube.com/watch?v=ub3mtKMw-q0 This clip shows the behind scenes of the experimental UK colour broadcast from January 1957 which the cameras and control room and equipment can be seen in their full glory! Also (I guess this would of been posted previously) the program itself exists in it's entirety on B&W kinescope and can be viewed on YouTube as well: Part 1: http://www.youtube.com/watch?v=b2MsQQ2UzVw Part 2: http://www.youtube.com/watch?v=6FN9MjWXyM0 Part 3: http://www.youtube.com/watch?v=V84-5rg3i8o Part 4: http://www.youtube.com/watch?v=jTHhyyWYW9E
AUSSIE AUSSIE AUSSIE!!!!! OI OI OI!!!!! |
noticed no one responded - just wanted to say thanks for the post
I watched 'em again....Wow...Still never have understood why color TV wasn't available in Blighty & the rest of Yoorup til so late, except for bureaucratic intransigence...And, of course, the desire on the part of some interests to tweak RCA's & America's collective nose a bit...
Benevolent Despot |
Maybe they waited until some of the important patents on color TV expired?
Some good reasons for taking so long: Never Twice Same Colour Cost - at both RX and TX ends Actually NTSC can work perfectly well with modern technology and a lot of care. |
Audiokarma |
US in 1940s should have taken the advice of some (Philco) and gone with higher res (700, 800 lines) but still, 525/60 NTSC would have been a good evolution from 405/50 for England in the late 50's as well as an original system for Aust/NZ (completing NTSC for the Pacific Rim). Would have made program distribution distribution a lot easier. To hell with non-English-speaking Continental Europe, let them keep their 625/50 (frame rate too slow for good motion) and their PAL (w/ its "Hanover Blinds" & half vert chroma resolution) and they can keep their Euro currency - which England wisely rejected. Last edited by NewVista; 06-01-2010 at 08:34 AM. |
Keep in mind England was considering 405/50 NTSC not changing to 525/60. It's nearly impossible to run the frame rate of the television at a different frequency from the AC power. (at least for crt based sets) This is why all 50Hz power countries use a 50Hz field rate, and 60Hz countries use 60Hz. Last edited by tubesrule; 06-01-2010 at 02:36 PM. |
Well, it was nearly impossible to do at a reasonable price with tubes at the time. Obviously eventually doable at reasonable cost with more sophisticated solid state power supplies, as demonstrated by millions of computer monitors.
Using systems with 25fps is unenlightened (based on 1920's 24fps film). It should not have been television spec by the 1950's. |
Colour made it impossible to use a mains (power line) locked field frequency. In the early days most systems relied on this to minimise the visibility of hum effects. Not sure which is more annoying; a slow moving hum bar or a 10Hz effect. |
Audiokarma |
The US had a mixture of 25, 50 and 60Hz power but had mostly settled on 60Hz by the time of commercial electronic television. You can still find 50Hz based US clocks from the 20's and 30's. Quote:
Hi old_tv_nut. This is what I was referring to but you did a better job elaborating. It was certainly doable with the power supplies of the time, but not practical or cost effective. Solid state based crt monitors did eliminate the ripple effect from the power supply, but you still had to deal with stray magnetic fields that could distort and ripple the image. This isn't quite the same comparison. 24fps film would look horrible and flicker badly if projected at 24fps. They realized this very early on and use a 2X or 3X shutter in the projector which fools the viewer into seeing 48fps or 72fps thus eliminating the flicker. Of course the content is still at 24fps so motion won't be as smooth giving it that "film" look. |
It's more than power supply filtering. Watching 50Hz video under 60Hz non incandescent lighting can be bothersome due to differing flicker rates. In my office, when I watch a 50Hz/Pal feed, the screen noticeably flickers when I light the room with fluorescent lighting. With good ol' inefficient incandescent lighting, it isn't nearly as bad. I'd suspect it's probably not as bad the other way around.
I won't even touch the fact that to some 60Hz viewers, a 50Hz video source flickers no matter what, until they eventually become used to it. |
I don't know what GB did in the 30's but can't see how they would achieve the necessary H/V relationship starting w/ 50hz ref. I would like to see a reference/link on this early SPG scheme.
That drove me nuts when I visited the UK and Ireland in 2000. I ended up "watching" Teletext most of the time the TV was on. Now, THAT was cool.
Visibility of flicker varies extremely strongly with absolute brightness, and varies somewhat from person to person. Some medicines can affect it. The last time I was in Europe, the TV in my room showed really visible flicker to me only on large bright areas - the average scene looked quite acceptable to me. One time (years ago) I had to use eyedrops for a few days to stop iritis (inflammation of the iris). This resulted in enhancing my flicker sensitivity to the point where I could see full modulation of the flicker from black to white on a 60 Hz NTSC display.
The colorwheel experiments done by Cliff Benham and shown at the early TV convention show that different people see different amounts of flicker at the CBS 24 frame/72 field rate, and everyone sees it on the NTSC wheel color converters. These experiments also show clearly that it is the luminance flicker that is visible, not chrominance. |
Audiokarma |
