Old 03-03-2011, 01:18 AM
miniman82's Avatar
First Light: 1952-2011
Necked roundie $140, Montgomery TX CL
no affiliation
http://houston.craigslist.org/fuo/2240128938.html
bad picture:
Evolution...
Old 03-03-2011, 05:32 AM
I was hoping that was just a real bad cat..
Old 03-03-2011, 09:26 AM
miniman82's Avatar
Pretty sure I'm seeing the phosphors blown off the tube face, but maybe it is a cat since the picture is so bad it's hard to tell. What make and model is it, BTW?
Evolution...
Old 03-03-2011, 11:37 AM
Looks like the CRT's popped to me. Too bad, from what you can tell it looked to be a nice set otherwise.
Old 03-03-2011, 12:11 PM
The seller said he cannot tell if the phonograph works because he does not have records to use to test it. He could have simply flicked the stylus with the unit on. If he heard noise in the speakers, the cartridge, the speakers and at least one amplifier are probably OK.
BTW, I think the phosphors are blown off the CRT screen, indicating, of course, that the neck was snapped off. I too had trouble even seeing the TV screen at first, until I increased my monitor brightness as high as it will go.
IMHO, whomever took that picture either did so without the flash or else tried to shoot it in semi- or total darkness, using only the flash. If he or she were using a cheap, small digital camera (or a cell phone cam) with an equally small flash tube, additional light will be required to get a decent picture, as the extremely small flash units in cameras such as the Radio Shack Flatfoto series are not nearly bright enough (or are timed not to stay on long enough) to illuminate the subject very well. There are no manual adjustments on these cameras for exposure or anything else--it is all automatic (typical point-and-shoot design), using what Radio Shack calls its "Autobrite" system. I have such a camera and have found that I need at least one other light on in the room in which I am taking a picture, in order to get a photo bright enough to see all the details and to prevent bright spots. This is especially important if, for example, I am taking a picture of my cat. She has green eyes; when the camera flash goes off, with no other light in the room it reflects off them, causing bright white spots where her eyes should be to show in the picture.
Old 03-03-2011, 01:58 PM
Blown phosphors for sure
I brightened it up as much as possible, definitely a blown tube, and a cataract to boot.
Old 03-03-2011, 02:54 PM
There are a lot of photographically challenged individuals with access to CL.
Old 03-03-2011, 06:41 PM
VintagePC's Avatar
Tube bug got me 05/2010
There are a lot of photographically challenged individuals FULL STOP
There. fixed that for you.... Forgot the likes of ****book and **space, did we?
Old 03-04-2011, 10:19 PM
gone now, wonder if anyone here got it?
