RCA CT-100 Channel Indicator Wheel Repair
Hello to All,
My working CT-100 has a damaged channel indicator disk/wheel. This was discovered last week when frequent channel changes were accomplished during recent maintenance operations by a US CT-100 Guru on the unit. As the following series of snapshots show, the disk/wheel is not broken (yet) but fragile, and therefore has been removed from active service to protect it from further damage. I am seeking your help to either: - Advice to reinforce/repair the original part. - Eventually offer a complete, structurally solid original part. If exactly the same part was used on other models of RCA TVs, that's fine by me. Please quote price/payment conditions by PM. I live in France, so please include USPS Air registered delivery. Thank! you! very much in advance for any help, Best Regards jhalphen Paris/France |
That same indicator wheel (fitting the KRK-12 series tuners) also came on high-end B&W sets of 1953-55. Some were convex shaped, (probably the 1955 models?)
They show up on eBay now & then, usually for $20 or so. That one of yours is very interesting since it has the different channel numbering Charles
Collecting & restoring TVs in Los Angeles since age 10 |
There were four blanks in the turret for UHF inserts that were purchased separately. They even came pre-tuned for the UHF channels in your area. Pop out the blank and insert. They drop right in. Mine do not have a number sheet with them though. That may have come with the set.
I am told that the strips are re-tuneable. I think mine are for Ch 31 and 59. Dave A
“Once you eliminate the impossible...whatever remains, no matter how improbable, must be the truth." Sherlock Holmes. |
The blank inserts were not purchased separately, each set came with all that you needed for your area.
julian |
I've repaired knobs with broken shafts before. I take a dremel tool with a cutoff disc and cut off the broken shaft, then sand it clean. I find another knob with the same sized shaft and do the same. I reattach the shaft from the donor knob with 1-ton epoxy. It works every time I've tried it.
This device isn't a spaceship, it's a time machine. It goes backwards, and forwards... it takes us to a place where we ache to go again. |
Audiokarma |
jhalphen
I had sent you e-mails on finding one of these..this time i thought i would post directly about where there is one of those channel indicator wheels..if still interested please e-mail me or send a message. terry |
