Zenith Roundie Craigslist Score!
I've been pretty lucky this summer. First, it was the necked Zenith Roundie with Power tuning I found on the Curb back in June. Today this followed me home:
It's a Zenith Model 5226UD. It uses a 25MC33 Chassis. The 21FJP22 tests super strong on all guns and has no Cataract or Green Halo! After cleaning a dirty power switch and tuner, I brought it up slowly on a variac. It mostly works. No matter what I do, I can't get the color to pop in. I checked the color killer and the service switch. Pulling the 6EW6 burst amp had no effect on the picture. Are there any common problem areas on this chassis that would cause this symptom? I'm guessing that a loss of Chroma must be the cause. Also, where in the heck are the vert size and linearity controls on this chassis? I can't find them anywhere! Chassis Shot |
As a former owner of that model/chassis here are some tips: The vertical size/lin controls are in the pencil box one is in the hollow shaft of the beige knob left of the green, the other is a hole between knobs.....The fishing lines exiting the yoke are the centering adjustments (don't assume they are garbage and try to rip them out).....On mine most of the tubes in the color section were dead or weak and I could not get any color till I changed them...Test those tubes and replace as needed.
PS the chassis shelf is flimsy; be careful not to rip off the back side of that groove that helps hold the back on.
Oh look. It seems to have the same issue as mine. Stretched at the top and smashed at the bottom.
Must be a common issue on this set. Good to see how all the stuff on the rear of the picture tube is set, though. |
Does anyone have a schematic for a 25MC33 chassis by chance? Quote:
I can definitely see what you mean about the cabinet shelf. The chipboard is, well, starting to shed chips, mostly from the bottom. I was wondering if I could brush a coat of heavy duty polyurethane on the chassis shelf to control the problem? Last edited by fsjonsey; 09-26-2015 at 01:35 AM. |
And I have the photofacts for this set. I am not sure how to duplicate it though |
Audiokarma |
i saw this set on craigslist.looks like the crt was replaced.glad someone grabbed it.post more pics
Nice score, I those sets.
There is a 100MF electrolytic capacitor connected to the cathode (pin 4) or the 6he5 vertical output tube that is almost always bad and will cause the lack of height. It is usually located on the underside of the chassis at the front. Replace it then do the height and linearity adjustments. This will need to be right before you try to converge the set. Get the black and white picture right before you worry to much about the color. Weak tubes could be a problem for the color, but check the vertical output tube as well and be sure it is healthy.
Audiokarma |
Most Zenith vert integrators were installed between the synch sep and the input to the first vertical multivibrator tube, and filter horizontal noise out of the synch....If it synchs good leave it be. Some times they also used them in the feedback from the vert output/second multivibrator to the first vert multivibrator section.
Never found a bad Zenith integrator so they would be far from the first thing I'd suspect as the problem. Get the caps and resistors in speck before you worry about it. The sam's should show the way replace it with discreet parts.
There are no integrators on this chassis. I just checked the schematic. So don't loose sleep over them. Do a google search for the chassis and the schematic is online at antiqueradios.com.
I'm going to keep close tabs on this post. His is suffering the same vertical issue mine is.
Mine gets excellent color, thanks to Electronic M getting that part of the set working. But both this one, and mine, have the identical issue with the vertical. |
Today I replaced all the ElMenco, Bumblebee, and other suspect paper caps under the chassis. I also replaced the 100uf electrolytic that feeds pin 4 of the vertical output tube that Bill R mentioned. Bill had it right. A new 100uf cap solved all the vertical issues. I now have full vertical height and good linearity. I still don't have color, despite also replacing all the tubes in the color section with NOS replacements. Where should I look next? The bad 100uf Electrolytic was a cardboard cased Sprague "Atom". Is it just my experience or are Sprague "Atoms" always bad? Last edited by fsjonsey; 10-01-2015 at 12:59 AM. |
Replacing it is a must on these. Mine still has the vertical issue, stretched at the top and compressed at the bottom. I'm working on doing away with C4 entirely, but the caps I ordered got lost in the mail, so I'm suffering a bit of pointless run around. The color issues might be in your tuner section. There is a very simple way to feed these sets A/V input to see if that produces color at all. I could post a picture from the schematic if interested, or how it was done on my chassis. |
Audiokarma |
