Old 12-24-2017, 10:19 AM
CRTs4life CRTs4life is offline
The Wayback Machine RGB thread is one of them.
This one is very popular as well: https://shmups.system11.org/viewtopic.php?f=6&t=56155
Merry Xmas everyone! Or whichever way you celebrate too.
Old 12-24-2017, 09:35 PM
Originally Posted by Jon A. View Post
I'm not familiar with the electron theory but negative on the electrolytic capacitors goes to ground; hooked up the other way they go poof.
Chances are you'll eventually tear up something, or at least do a sloppy job and want to re-do it eventually, I did quite a bit in the early stages of the learning process. By the way I always use 105 degree Nichicon capacitors. Avoid oddly-branded Chinese caps at all cost.
Hi Jon
In this case the caps are for "coupling". They pass the "AC" part of the
signal & block DC. Caps to ground are usually for "decoupling".
They pass varying signals to ground to keep B+ lines as clean as needed.
They "save" voltage & let it go when needed as the B+ sinks.
Old 12-25-2017, 02:08 AM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
Hi Jon
Ah yes, that first part occurred to me not long after making that post, I thought it an odd place to use an electrolytic. The "negative towards the TV" part threw me at first.
I can hardly wait to get restarted on my own set's repairs, the weird waveform on the convergence board has me stumped at the moment.
