predicta princess flyback test jig
trying to build a test jig for the predicta princess flyback.
the idea is to disconnect the plate lead from the HO tube, and make a jumper that goes from the existing flyback as mounted to the jig (bypass the jig for vert use the jig for horz). The jig would then have leads for connecting to the damper (at the choke) and HV lead from the test fly back to the HV rec. only thing left to hook up would be the test fly HO lead to the HO tube. I know I could do it with a bunch of alligator lead, but would rather not hook up the the set (yoke lead) that way. anyway I need to know what the multipin connector (male and female) is called. then I can try different flys to see if I can make something work that is not an exact replacement (I have a lot of old BW flys 110 degree that I "think" may work). |
