Go Back   Videokarma.org TV - Video - Vintage Television & Radio Forums > General Off Topic Forums
Old 10-06-2017, 04:13 PM
Telecolor 3007's Avatar
I love old stuff
FP flash bulbs/lights
There where some type of flashbulbs that allowed some cameras that have slow sync flash speed to use sync speeds up to 1/500 or 1/1000 seconds. How can you make the difference between an standard Magensium bulb and F.P. one.
Sailor Moon
Old 10-06-2017, 09:34 PM
The bulb packaging would have a type number including the letters FP, like "FP-26". I don't recall for sure if the bulbs would be marked individually, but I think they would.
Here's a place that lists some types of bulbs:
http://www.flashbulbs.com/ClearBulbs.htm
Old 10-07-2017, 03:23 AM
I love old stuff
But can I put such bulbs in every flash unit that can fit them or do i need a special flash unit?
Sailor Moon
Old 10-07-2017, 09:23 AM
You can use them in any flash unit they fit into. The only important point is that to use them with a short duration focal plane shutter, the camera must have the correct sync timing (M sync). Two things cooperate in this action:
1) the shutter slit opens and starts to travel after a short delay to allow the bulb to reach full brightness
2) the FP bulb maintains full brightness for a longer time than a regular bulb, allowing time for the shutter slit to travel across the whole image
Old 10-07-2017, 09:32 AM
The GE brochure on this site shows the difference between regular and FP bulbs:
http://www.flashbulbs.com/flash_info.htm
Old 10-07-2017, 10:26 AM
I love old stuff
I will study more that site.
I have an "Minolta" SRT-101 with FP connector.
But it's strange that I've seen that "Sylvania" was saying for they bulbs that FP comes from something elese.
Sailor Moon
Old 10-07-2017, 04:01 PM
Sorry, I confused M and FP bulbs.
The Minolta manual shows the difference in shutter speed range on p.31:
http://www.cameramanuals.org/minolta...ta_srt-101.pdf
If you download the manual, you should leave a small donation to support the site.
Old 10-07-2017, 05:46 PM
I love old stuff
I know that site. That's where I found about the F.P. flash bulbs.
I'll make a donation when I will have an bank account or I will put money on my "Pay Pal" acount.
But is the "Philips" FP5B a normal F or M bulb or an F.P. bulb? http://www.flashbulbs.com/Philips_ph-1.htm
I found for sale the FP5 version... probably only for black and white films.
Sailor Moon
Old 10-07-2017, 06:28 PM
Look again at the Philips page. I think you made a mistake when reading. It says "PF5B", not "FP5B." I think "PF" stands for their trademark "Photo Flux," or "Photo Flash," not "Focal Plane."
The light curve for the PF bulbs is very peaked, not flat-topped like a focal plane bulb.
Old 10-07-2017, 06:32 PM
Also, the FP5 is probably a clear bulb? So it would not be for color film requiring daylight color.
Old 10-08-2017, 03:07 AM
I love old stuff
Yes, my bad, it's PF.
So the light curve must be like the one from the 2 diagrams from the low right of this image: http://www.flashbulbs.com/CrPDwnlds/FlashInfoPdf2Sm.gif
Sailor Moon
Old 10-08-2017, 10:35 AM
That is correct.
Old 10-09-2017, 11:10 AM
I love old stuff
But generally speaking, bigger bulbs (not as big as one with E27 screw mount) had more power then small one that didn't had theyr own socket, but in stad 2 wires getting outside (I have about 20 with that wires...).
Sailor Moon
