Old 09-25-2012, 12:28 PM
Bill Cahill's Avatar
Super Moderator
Smile Restoration of RCA Victor R-98 1939 table top victrola
Hi.
I've had this machine for more than 30 years.. At one time I had it playing, but, sound was weak. Then, other problems happenned, and, it got set asside for the last 24 years. I'm now finally back on it.
Started out by polishing the chassis, and, speaker.
I have repairs to do, and, case work to do.
Pictures are mixed, up. Sorry. But, I'll be doing this possibly in sections.
Well, here goes. Here are photos of it. Oh. By the way.
Tube line up follows: 1 5U4 Rect. 2 2A3 Audio Output. 2 6J5. ONe is inverter, other is pre amp.
It uses a driver transformer for ouput stage.
Well, what do you guys think? It was sort of playing 24 years ago, but, after getting the correct schematic for it, I found out the electrolytics I had put in, all at 450 volts, were too low. I needed 500 volt instead..
I think several of the parts are chrome plated.
I believe apeaker frame is also chrome plated.
Magnet assembly isn't.
Bill Cahill
Please join my forum.
Old 09-25-2012, 12:38 PM
Super Moderator
Smile
Here are more pictures of it.
Bill Cahill
Old 09-26-2012, 10:50 AM
maxhifi's Avatar
maxhifi maxhifi is offline
Wow did you say push pull 2A3s, in a table top phono? This thing is awesome, certainly one of the nicest of the sort I've ever seen. I can't believe that by 1939 it wasn't based on a 50L6 output stage or at best a 6V6. I hope you get it going. I'd be tempted to modify it to play LPs to get a bit more use out of that amazing amplifier and speaker!
Old 09-26-2012, 07:33 PM
Super Moderator
Smile
I have plenty of 78's, so, no prolblem there.
I'll get it playing again. I had it playing to some degree then.
This was a fairly expensive machine. Yep. I did say two 2A3's in push pull.
According to RCA records it puts out 12-13.5 watts of audio power.
It's a good machine.............
Thanks.
Bill Cahill
Old 09-29-2012, 10:06 AM
holmesuser01's Avatar
I'd happily take those old klunky 2A3's off your hands, Bill...
Seriously, that's a great amplifier.
I got one built around 1933 that was used for back-up in a movie theatre for about 60 years that used 4-2A3's. Two were missing, and I was amazed to find 2 in my tube stash. They all check very good.
I did a full re-cap on it, and I use it with an FM tuner today. It sounds really nice.
I look forward to the progress on this phono. I've got projects that have sat around just as long as this one has for you.
All the best!
Bruce
Old 09-30-2012, 08:15 PM
Super Moderator
Post
Tried amplifier yesterday. I ended up having to try a cheap crystal cartridge.
Not touched original player yet.
Amp has good, clean sound, but, lackng bass.
I suspect mica caps are shot.
I'll have to work on that.
When I rebuilt it I used mylar caps on output stage. It had paper caps. Yet, schematic called for mica caps there. Someone may have replaced those long ago.
One of the cans had been replaced with a cardboard 450 volt filter. That's long gone, now.................
Well, it works, but, needs more work. When that's done, I'll bring cabinet into the shop, and, replace bad pick-up wire.
Bill Cahill
Old 10-01-2012, 05:02 PM
Super Moderator
Hope to get back on it tommorrow. Vol. was o.k., but, not great. Found out coupling resistor for cartridge had doubled. I'll replace that.
I think what's left of mica caps have gone south.
I'll replace them.
The volume control in this actually has two tone taps. Not bad, says I.
Speaker is good, and, transformers are still good.
Wheww!!!!!
Bill Cahill
Old 10-01-2012, 05:27 PM
Homina, homina, homina....drool...(wipes mouth). That thing must be the E.H. Scott of 78rpm phonos.
I bet it will sound GREAT when you are finished working on it.
Old 10-06-2012, 08:50 AM
Super Moderator
Post
It's been a rough week here, so, in spite of getting some caps for it, I haven't been able to work on it, yet. Hope to soon.
I'll post when I do....
Thanks.
Bill Cahill
Old 10-06-2012, 11:35 AM
That's a nice machine and I hope you get it going soon!
Old 10-07-2012, 11:22 AM
Reece's Avatar
Reece Reece is offline
That's really hunky for a table top record player. Wonder if it was intended for something like school use, powerful output and manual player, no radio. The chassis is full of extra holes plugged up: wonder if the chassis was shared with a radio model or PA amp or some other product.
Reece
Old 10-07-2012, 04:10 PM
Super Moderator
Smile
Looks like it might have been also used for one of their radios.
The plugs are nickel plated, also.
Bill Cahill
Old 10-15-2012, 11:45 PM
Super Moderator
Smile
I posted this in both ARF, amd, my own forum tonight. Thought you'd be interested. Here goes................
I have had this machine for over 35 years. When I got it it was still barely playing with it's original 1939 factory Crystal cartridge.
I repaired it at the time, and, it put out some audio, but, not alot.
Well, alot happenned, and, I haven't touched it in 20 years, approx.
I got back on it about two weeks ago after my flyback fried in my Raytheon tv.
I put new electrolytics in it again, and, started repairs.
Well, it's still got issues, but, guess what!!
The original crystal cartridge is still very much alive!!!!!!
The wire leading to it was shorted because rubber insulation on center wire had crumbled off.
The wires solder to the back of the cartridge, and, there is a shorting switch mounted on the cartridge to short it out while changing needles.
I don't have great wire, and, it's causing me major headaches. But, with fiddling around, I get fairly decent volume out of that cartridge, with good bass response.
I can't play a record yet because of mechanical problems, including a gummed up motor.
But, with difficulty, I can drag a record, and, it had decent volume, admittedly with vol control turned all the way up, but, still, decent volume, with good bass.
I'm not even going to rebuild this one. I'm leaving this cartridge alon!!!!
Bill Cahill
Old 10-16-2012, 01:28 AM
Super Moderator
Smile
Did some messing around with motor, and, connections, and, a fussy mercury switch, and, got it to play records. With original old saphire needle it was distorted. I put a new 78 needle in, and, now, it plays GREAT!!!!!
Lots of volume, good bass, clean, and, clear.
I am IMPRESSED!!!!!
Bill Cahill
Old 10-16-2012, 02:58 PM
Reece's Avatar
That's some find. Does it have any other function, like a mike input? Or just plays records?
EDIT: answered my own question; it plays records only. Here's the schematic. Quite a player.
http://www.nostalgiaair.org/PagesByM...5/M0015735.pdf
Reece
